[mapserver-dev] RE: [mapserver-users] PHP mapscript -how
toaddlabel style
Andrew Monteiro
amonteiro at dbxgeomatics.com
Tue Oct 25 10:46:00 EDT 2011
Hi Alan,
"new styleObj()" is not permitted. I could use 'new styleObj(null)'.
However that would give me a styleobj instance that is not associated
with anything. I'm trying to associate a style with a label, as per the
new organization.
There is no way to assign a style object you create to anything except
by using the constructor's classObj parameter. i.e. if I was to do "new
styleObj(null)" there is no way after that to associate that styleObj
instance with a class instance or a label instance.
Hence, we need to add another constructor to the style object along the
lines of "new styleObj(someLabelObj)" or have some method that allows a
style object to be associated with a class instance and/or a label
instance.
I'm not sure if you want to do it outside of the constructor in case you
end up with a styleObj instance associated with multiple class/labels.
I'm not sure if that's a good thing for the internals, or a good thing
programmatically either.
Hope that make sense.
Cheers!
Andrew
-----Original Message-----
[mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Alan
Boudreault
Sent: October 25, 2011 8:39 AM
To: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] RE: [mapserver-users] PHP mapscript -how
toaddlabel style
Andrew,
Are you saying that "new styleObj()" is not allowed? I haven't modified
that part of swig... and checking the code parent_class==NULL is
supposed to be allowed.
Alan
On 11-10-24 12:04 PM, Andrew Monteiro wrote:
> Looks like the C# bindings did not get updated.
> I downloaded the latest daily build binaries from
> http://vbkto.dyndns.org/sdk/.
> MSVC2010 (Win32)
> release-1600-gdal-1-8-mapserver-6-0
> finished at 2011.10.24. 8:12:20,18
> r12689, r23275
> I am using c# .Net4, and the only option I have for creating a Style
> object is
> new styleObj(classObj parent_class)
> Cheers,
> Andy
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Andrew
> Monteiro
> Sent: October 18, 2011 10:54 AM
> Subject: RE: [mapserver-dev] RE: [mapserver-users] PHP mapscript - how
> toaddlabel style
> I'll try to get to the C# test later this week. I'm unfortunately out
of
> the office most of today and tomorrow.
> Andy
> Boudreault
> Sent: October 17, 2011 4:56 PM
> Subject: Re: [mapserver-dev] RE: [mapserver-users] PHP mapscript - how
> toadd label style
> I have committed a patch in trunk. Feel free to test. I have also
fixed
> the SWIG part... but only tested in python. If anyone could test it in
> java,perl or csharp, it would be nice.
> Note: to insert a style... it's different for php vs swig bindings.
Just
> use the same thing you would have used for the classObj:
> - PHP: new styleObj(myLabel)
> - SWIG: label.insertStyle(styleObj())
> Thanks,
> Alan
> On 11-10-17 01:15 PM, Alan Boudreault wrote:
>> I'm currently looking at this issue.
>> Alan
>> On 11-10-16 09:56 PM, Ian Walberg wrote:
>>> Folks,
>>> Is this something we can help add?
>>> Regards
>>> Ian
>>> From: mapserver-users-bounces at lists.osgeo.org
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ian
>>> Walberg
>>> Sent: Monday, October 03, 2011 12:26 PM
>>> To: Steve Lime
>>> Cc: mapserver-users at lists.osgeo.org
>>> Subject: RE: [mapserver-users] PHP mapscript - how to add label
style
>>> http://trac.osgeo.org/mapserver/ticket/4038
>>> From: Steve Lime [mailto:sdlime at gmail.com]
>>> Sent: Wednesday, September 28, 2011 8:30 PM
>>> To: Ian Walberg
>>> Subject: Re: [mapserver-users] PHP mapscript - how to add label
style
>>> I'm guessing this is a bug, could you quick file a ticket and we'll
> make
>>> sure this is addressed in 6.0.2?
>>> Steve
>>> On Tue, Sep 27, 2011 at 10:21 AM, Ian Walberg
>>> <ian.walberg at airborne.aero> wrote:
>>>> Hello,
>>>> I am sure it is staring me in the face but we cannot see how to add
> a
>>>> style to a label (Mapserver 6.x) using PHP mapscript.
>>>> Works fine via map file and we see the open issue with the save not
>>>> including the geotransform line.
>>>> What are we missing?
>>>> Thanks
>>>> Ian
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> mapserver-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
