[mapserver-dev] RE: [mapserver-users] PHP mapscript
-how toaddlabel style
Alan Boudreault
aboudreault at mapgears.com
Tue Oct 25 10:46:18 EDT 2011
As mentionned in my previous mail, In all SWIG Bindings (this includes
C#), you have to use the following label method:
label.insertStyle(styleObj(null))
Thanks,
Alan
On 11-10-25 10:46 AM, Andrew Monteiro wrote:
> Hi Alan,
> "new styleObj()" is not permitted. I could use 'new styleObj(null)'.
> However that would give me a styleobj instance that is not associated
> with anything. I'm trying to associate a style with a label, as per the
> new organization.
> There is no way to assign a style object you create to anything except
> by using the constructor's classObj parameter. i.e. if I was to do "new
> styleObj(null)" there is no way after that to associate that styleObj
> instance with a class instance or a label instance.
> Hence, we need to add another constructor to the style object along the
> lines of "new styleObj(someLabelObj)" or have some method that allows a
> style object to be associated with a class instance and/or a label
> instance.
> I'm not sure if you want to do it outside of the constructor in case you
> end up with a styleObj instance associated with multiple class/labels.
> I'm not sure if that's a good thing for the internals, or a good thing
> programmatically either.
> Hope that make sense.
> Cheers!
> Andrew
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Alan
> Boudreault
> Sent: October 25, 2011 8:39 AM
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] RE: [mapserver-users] PHP mapscript -how
> toaddlabel style
> Andrew,
> Are you saying that "new styleObj()" is not allowed? I haven't modified
> that part of swig... and checking the code parent_class==NULL is
> supposed to be allowed.
> Alan
> On 11-10-24 12:04 PM, Andrew Monteiro wrote:
>> Looks like the C# bindings did not get updated.
>> I downloaded the latest daily build binaries from
>> http://vbkto.dyndns.org/sdk/.
>> MSVC2010 (Win32)
>> release-1600-gdal-1-8-mapserver-6-0
>> finished at 2011.10.24. 8:12:20,18
>> r12689, r23275
>> I am using c# .Net4, and the only option I have for creating a Style
>> object is
>> new styleObj(classObj parent_class)
>> Cheers,
>> Andy
>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Andrew
>> Monteiro
>> Sent: October 18, 2011 10:54 AM
>> Subject: RE: [mapserver-dev] RE: [mapserver-users] PHP mapscript - how
>> toaddlabel style
>> I'll try to get to the C# test later this week. I'm unfortunately out
> of
>> the office most of today and tomorrow.
>> Andy
>> Boudreault
>> Sent: October 17, 2011 4:56 PM
>> Subject: Re: [mapserver-dev] RE: [mapserver-users] PHP mapscript - how
>> toadd label style
>> I have committed a patch in trunk. Feel free to test. I have also
> fixed
>> the SWIG part... but only tested in python. If anyone could test it in
>> java,perl or csharp, it would be nice.
>> Note: to insert a style... it's different for php vs swig bindings.
> Just
>> use the same thing you would have used for the classObj:
>> - PHP: new styleObj(myLabel)
>> - SWIG: label.insertStyle(styleObj())
>> Thanks,
>> Alan
>> On 11-10-17 01:15 PM, Alan Boudreault wrote:
>>> I'm currently looking at this issue.
>>> Alan
>>> On 11-10-16 09:56 PM, Ian Walberg wrote:
>>>> Folks,
>>>> Is this something we can help add?
>>>> Regards
>>>> Ian
>>>> From: mapserver-users-bounces at lists.osgeo.org
>>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ian
>>>> Walberg
>>>> Sent: Monday, October 03, 2011 12:26 PM
>>>> To: Steve Lime
>>>> Cc: mapserver-users at lists.osgeo.org
>>>> Subject: RE: [mapserver-users] PHP mapscript - how to add label
> style
>>>> http://trac.osgeo.org/mapserver/ticket/4038
>>>> From: Steve Lime [mailto:sdlime at gmail.com]
>>>> Sent: Wednesday, September 28, 2011 8:30 PM
>>>> To: Ian Walberg
>>>> Subject: Re: [mapserver-users] PHP mapscript - how to add label
> style
>>>> I'm guessing this is a bug, could you quick file a ticket and we'll
>> make
>>>> sure this is addressed in 6.0.2?
>>>> Steve
>>>> On Tue, Sep 27, 2011 at 10:21 AM, Ian Walberg
>>>> <ian.walberg at airborne.aero> wrote:
>>>>> Hello,
>>>>> I am sure it is staring me in the face but we cannot see how to add
>> a
>>>>> style to a label (Mapserver 6.x) using PHP mapscript.
>>>>> Works fine via map file and we see the open issue with the save not
>>>>> including the geotransform line.
>>>>> What are we missing?
>>>>> Thanks
>>>>> Ian
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>> mapserver-dev mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
