[mapserver-dev] INSPIRE view service questions for FOSS4g talk
Stephan Meißl
stephan at meissl.name
Sat Sep 17 15:41:19 EDT 2011
Hi Tom,
trying to follow this up on the FOSS4G code sprint. Thanks for your
compliancy presentation with the good results for MapServer ;). Was
great meeting you at the FOSS4G!
Regarding your points below, for 1. Looking at the capabilities under
[1] the layers report multiple bounding boxes. Which setting did you use
in your mapfile? For 2. and 3. Stefan sent you a response. Did you see
it?
To find the documentation of the developments of Stefan its best to
start at [2]. The RFC will soon be posted to the official location.
cu
Stephan
[1] http://trac.osgeo.org/mapserver/browser/sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130.xml
[2] http://trac.osgeo.org/mapserver/wiki/gsoc2011
On Sun, 2011-09-11 at 07:47 -0700, tellett wrote:
> Hi all,
> I'm doing a talk at FOSS4g on INSPIRE compliancy of view services. IN the
> course of this I've come across a few issues that I wonder if anyone can
> clarify for me.
> 1. It appears that you cannot specify multiple bounding boxes on layers if
> you have specified multiple CRS's.
> 2. ResourceLocator metadata is a missing option in the mapfile
> 3. There is no way of specifying a vocabulary attribute for keywords.
> The only docs I've found for any of these is a closed bug report for the
> multiple bounding box issue. Can anyone confirm if the other two issues are
> still a problem and if so if anything is planned to fix them? They are all
> mandatory requirements for INSPIRE. I have checked out Stefan Leopolds code
> and have been using that to check INSPIRE compliancy.
> Thanks in advance
> Tom
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/INSPIRE-view-service-questions-for-FOSS4g-talk-tp6780910p6780910.html
> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
