[mapserver-dev] Re: INSPIRE view service questions for FOSS4g talk
tellett
thomas.ellett at statkart.no
Tue Sep 27 05:14:54 EDT 2011
Hei Stephan,
Sorry its taken me so long to reply and it was great meeting you in Denver
as well, always nice to put a face to a name!
Firstly, I haven't seen anything from Stefan about points 2 and 3, but I'd
love to hear what he thinks. Secondly, I tried multiple settings to get
multiple bounding boxes in the capabilities file but none of them worked.
Unless bug #1905 has been fixed I'm assuming Mapserver just doesn't support
this in any shape or form (and I can fully understand why!!).
cheers
Tom
Stephan Meißl wrote:
> Hi Tom,
> trying to follow this up on the FOSS4G code sprint. Thanks for your
> compliancy presentation with the good results for MapServer ;). Was
> great meeting you at the FOSS4G!
> Regarding your points below, for 1. Looking at the capabilities under
> [1] the layers report multiple bounding boxes. Which setting did you use
> in your mapfile? For 2. and 3. Stefan sent you a response. Did you see
> it?
> To find the documentation of the developments of Stefan its best to
> start at [2]. The RFC will soon be posted to the official location.
> cu
> Stephan
> [1]
> http://trac.osgeo.org/mapserver/browser/sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130.xml
> [2] http://trac.osgeo.org/mapserver/wiki/gsoc2011
> On Sun, 2011-09-11 at 07:47 -0700, tellett wrote:
>> Hi all,
>> I'm doing a talk at FOSS4g on INSPIRE compliancy of view services. IN the
>> course of this I've come across a few issues that I wonder if anyone can
>> clarify for me.
>> 1. It appears that you cannot specify multiple bounding boxes on layers
>> if
>> you have specified multiple CRS's.
>> 2. ResourceLocator metadata is a missing option in the mapfile
>> 3. There is no way of specifying a vocabulary attribute for keywords.
>> The only docs I've found for any of these is a closed bug report for the
>> multiple bounding box issue. Can anyone confirm if the other two issues
>> are
>> still a problem and if so if anything is planned to fix them? They are
>> all
>> mandatory requirements for INSPIRE. I have checked out Stefan Leopolds
>> code
>> and have been using that to check INSPIRE compliancy.
>> Thanks in advance
>> Tom
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/INSPIRE-view-service-questions-for-FOSS4g-talk-tp6780910p6780910.html
>> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
View this message in context: http://osgeo-org.1803224.n2.nabble.com/INSPIRE-view-service-questions-for-FOSS4g-talk-tp6780910p6835250.html
