[mapserver-dev] Re: INSPIRE view service questions for FOSS4g talk
Martin Kofahl
M.Kofahl at gmx.net
Tue Sep 27 07:53:28 EDT 2011
Hi Thomas,
take a look at http://trac.osgeo.org/mapserver/ticket/3602 regarding multiple bounding boxes. It's working fine, but you may require a patch for the proj4 lib, see http://trac.osgeo.org/proj/ticket/100.
Regarding 2 and 3, there's a raw patch in the trac, see #3608. I have MapServer with the mandatory INSPIRE metadata running since May and it passed the validator.
Best regards,
Martin
-------- Original-Nachricht --------
> Datum: Tue, 27 Sep 2011 02:14:54 -0700 (PDT)
> Von: tellett <thomas.ellett at statkart.no>
> An: mapserver-dev at lists.osgeo.org
> Betreff: [mapserver-dev] Re: INSPIRE view service questions for FOSS4g talk
> Hei Stephan,
> Sorry its taken me so long to reply and it was great meeting you in Denver
> as well, always nice to put a face to a name!
> Firstly, I haven't seen anything from Stefan about points 2 and 3, but I'd
> love to hear what he thinks. Secondly, I tried multiple settings to get
> multiple bounding boxes in the capabilities file but none of them worked.
> Unless bug #1905 has been fixed I'm assuming Mapserver just doesn't
> support
> this in any shape or form (and I can fully understand why!!).
> cheers
> Tom
> Stephan Meißl wrote:
> > Hi Tom,
> > trying to follow this up on the FOSS4G code sprint. Thanks for your
> > compliancy presentation with the good results for MapServer ;). Was
> > great meeting you at the FOSS4G!
> > Regarding your points below, for 1. Looking at the capabilities under
> > [1] the layers report multiple bounding boxes. Which setting did you use
> > in your mapfile? For 2. and 3. Stefan sent you a response. Did you see
> > it?
> > To find the documentation of the developments of Stefan its best to
> > start at [2]. The RFC will soon be posted to the official location.
> > cu
> > Stephan
> > [1]
> http://trac.osgeo.org/mapserver/browser/sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130.xml
> > [2] http://trac.osgeo.org/mapserver/wiki/gsoc2011
> > On Sun, 2011-09-11 at 07:47 -0700, tellett wrote:
> >> Hi all,
> >> I'm doing a talk at FOSS4g on INSPIRE compliancy of view services. IN
> the
> >> course of this I've come across a few issues that I wonder if anyone
> can
> >> clarify for me.
> >> 1. It appears that you cannot specify multiple bounding boxes on layers
> >> if
> >> you have specified multiple CRS's.
> >> 2. ResourceLocator metadata is a missing option in the mapfile
> >> 3. There is no way of specifying a vocabulary attribute for keywords.
> >> The only docs I've found for any of these is a closed bug report for
> the
> >> multiple bounding box issue. Can anyone confirm if the other two issues
> >> are
> >> still a problem and if so if anything is planned to fix them? They are
> >> all
> >> mandatory requirements for INSPIRE. I have checked out Stefan Leopolds
> >> code
> >> and have been using that to check INSPIRE compliancy.
> >> Thanks in advance
> >> Tom
> >> View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/INSPIRE-view-service-questions-for-FOSS4g-talk-tp6780910p6780910.html
> >> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
> >> _______________________________________________
> >> mapserver-dev mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> http://osgeo-org.1803224.n2.nabble.com/INSPIRE-view-service-questions-for-FOSS4g-talk-tp6780910p6835250.html
