[mapserver-dev] mapcache grid
Jachym Cepicky jachym.cepicky at gmail.com
Tue Sep 20 05:16:49 EDT 2011
hi,
I would like to make some tests with MapCache
In the documentation [1] it is said, that you can make choice out of two
predefined grid options: "WGS84" an "g".
Do I understand it correctly, that I could configure my custom grid,
which will be defined by
	tile size
	max extent
	resolutions/scales
How? I did not found this in the documentation.
Thanks for hint
Jachym
P.S. It is clear to me, the project is in relatively early-development
stage. But seems promising.
[1] http://www.mapserver.org/trunk/mapcache/mapcache_config.html
