[mapserver-dev] mapcache grid
thomas bonfort
thomas.bonfort at gmail.com
Tue Sep 20 05:57:28 EDT 2011
The provided mapcache.xml is commented and should provide the
necessary steps to configure your own grid.
thomas
On Tue, Sep 20, 2011 at 11:16, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> hi,
> I would like to make some tests with MapCache
> In the documentation [1] it is said, that you can make choice out of two
> predefined grid options: "WGS84" an "g".
> Do I understand it correctly, that I could configure my custom grid, which
> will be defined by
> tile size
> max extent
> resolutions/scales
> How? I did not found this in the documentation.
> Thanks for hint
> Jachym
> P.S. It is clear to me, the project is in relatively early-development
> stage. But seems promising.
> [1] http://www.mapserver.org/trunk/mapcache/mapcache_config.html
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
