[mapserver-dev] mapcache grid
Jachym Cepicky jachym.cepicky at gmail.com
Wed Sep 21 04:16:57 EDT 2011
great, thanks, it worked
another question: is there described, how to write mapcache as service?
I have apparently compiled and install the apache module (or I hope so),
what's next?
I have two binaries in mapcache/src/
mapcache
mapcache_seed
Thanks
Jachym
On 20.9.2011 11:57, thomas bonfort wrote:
> The provided mapcache.xml is commented and should provide the
> necessary steps to configure your own grid.
> thomas
> On Tue, Sep 20, 2011 at 11:16, Jachym Cepicky<jachym.cepicky at gmail.com>  wrote:
>> hi,
>> I would like to make some tests with MapCache
>> In the documentation [1] it is said, that you can make choice out of two
>> predefined grid options: "WGS84" an "g".
>> Do I understand it correctly, that I could configure my custom grid, which
>> will be defined by
>>         tile size
>>         max extent
>>         resolutions/scales
>> How? I did not found this in the documentation.
>> Thanks for hint
>> Jachym
>> P.S. It is clear to me, the project is in relatively early-development
>> stage. But seems promising.
>> [1] http://www.mapserver.org/trunk/mapcache/mapcache_config.html
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
