[mapserver-dev] mapcache grid
thomas bonfort thomas.bonfort at gmail.com
Wed Sep 21 21:11:29 EDT 2011
On Wed, Sep 21, 2011 at 10:16, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> Hi,
> great, thanks, it worked
> another question: is there described, how to write mapcache as service?
I don't understand the question
> I
> have apparently compiled and install the apache module (or I hope so),
> what's next?
(sudo) make install-module will activate the module in the apache
configuration. You then have to add a
MapcacheAlias /mapcache /path/to/mapcache.xml
restart apache, and go to http://server/mapcache/demo to see your
configured layers.
thomas
> I have two binaries in mapcache/src/
> mapcache
> mapcache_seed
> Thanks
> Jachym
> On 20.9.2011 11:57, thomas bonfort wrote:
>> The provided mapcache.xml is commented and should provide the
>> necessary steps to configure your own grid.
>> thomas
>> On Tue, Sep 20, 2011 at 11:16, Jachym Cepicky<jachym.cepicky at gmail.com>
>>  wrote:
>>> hi,
>>> I would like to make some tests with MapCache
>>> In the documentation [1] it is said, that you can make choice out of two
>>> predefined grid options: "WGS84" an "g".
>>> Do I understand it correctly, that I could configure my custom grid,
>>> which
>>> will be defined by
>>>        tile size
>>>        max extent
>>>        resolutions/scales
>>> How? I did not found this in the documentation.
>>> Thanks for hint
>>> Jachym
>>> P.S. It is clear to me, the project is in relatively early-development
>>> stage. But seems promising.
>>> [1] http://www.mapserver.org/trunk/mapcache/mapcache_config.html
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
