[mapserver-dev] Re: RFC for XMP metadata support
Paul Ramsey
pramsey at opengeo.org
Thu Sep 22 13:56:05 EDT 2011
Long delay, but I've updated the RFC (attached) and updated the patch
to be generic and work as described in the new RFC, similar to what
Daniel describes below. Any XMP tag can be set, and some default
namespaces are supported as well as the ability to define new custom
name spaces in XMP.
If there's no substantial concerns, I'll move the RFC into the queue
for voting with a proper number.
Yours,
Paul
On Thu, Jul 7, 2011 at 8:45 AM, Daniel Morissette
<dmorissette at mapgears.com> wrote:
> Hi Paul,
> Here are a few questions/comments:
> - The proof of concept code attached to ticket #3932 is executed in all
> cases. The real implementation should be conditional to the presence of
> xmp_* metadata to avoid calling xmp_init() and reopening the output file
> unnecessarily when this feature is not used. (I presume you were going to do
> that already but that was not explicitly stated in the RFC)
> - Instead of focusing on license metadata, could we not make it so that any
> xmp_* metadata triggers this feature and ends up writing the corresponding
> metadata to the output?
> - As Thomas already pointed out, it would be ideal to have support for this
> via the default output formats as well and not just GDAL based formats
> Daniel
> On 11-07-07 11:29 AM, Paul Ramsey wrote:
>> No concerns, questions?
>> On Mon, Jul 4, 2011 at 9:10 AM, Paul Ramsey<pramsey at cleverelephant.ca>
>> wrote:
>>> Devs,
>>> I've prepared a draft RFC for adding embedded metadata into output
>>> images produced by MapServer.
>>> http://trac.osgeo.org/mapserver/attachment/ticket/3932/ms-rfc-7X.txt
>>> I'm looking for feedback now before I number and commit it and ask for
>>> a vote. Here's the preamble so you don't have to click:
>>> XMP is the "extensible metadata platform" [1]_ which allows the
>>> embedding of metadata information across a wide range of document and
>>> image formats: PNG, GIF, JPEG, PDF, etc. XMP was originally developed
>>> by Adobe [2]_ and is supported across their product line. It is now
>>> being increasingly included in other standards for metadata embedding
>>> and supported by tools for viewing image information (e.g. exiftools).
>>> Creative Commons has standards for using XMP to embed commons
>>> licensing [3]_ in images and other document, including a specific
>>> creative commons schema. One of the challenges of advertising
>>> licensing and terms of use in WMS and other web mapping services is
>>> that the terms are usually advertised separately from the actual
>>> content. So a WMS service might specify terms in the Capabilities
>>> document, but the images themselves will be unmarked. Embedding
>>> license URLs inside the images themselves using a standard marking
>>> allows organizations to be unambiguous about the conditions attached
>>> to their content.
>>> The goal of this change is to allow users the option of embedding XMP
>>> metadata in their MapServer output using an open source XMP utility
>>> library.
>>> .. [1] http://en.wikipedia.org/wiki/Extensible_Metadata_Platform
>>> .. [2] http://www.adobe.com/products/xmp/overview.html
>>> .. [3] http://wiki.creativecommons.org/XMP
>>> .. [4] http://libopenraw.freedesktop.org/wiki/Exempi
>>> Thanks,
>>> Paul
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Daniel Morissette
> http://www.mapgears.com/
> Provider of Professional MapServer Support since 2000
.. _rfc7X:
MS RFC 7X: Adding License Metadata to Output Images
:Date: 2011/06/22
:Author: Paul Ramsey
:Contact: pramsey at opengeo.org
:Last Edited: $Date$
:Status: Draft
:Version: MapServer 6.2
:Id: $Id$
Description: This RFC proposes allowing XML metadata information to be embedded in MapServer output images. The use case is for any organization producing maps that wishes to embed licensing and authorship information directly in the output images.
1. Overview
XMP is the "extensible metadata platform" [1]_ which allows the embedding of metadata information across a wide range of document and image formats: PNG, GIF, JPEG, PDF, etc. XMP was originally developed by Adobe [2]_ and is supported across their product line. It is now being increasingly included in other standards for metadata embedding and supported by tools for viewing image information (e.g. exiftools). Creative Commons has standards for using XMP to embed commons licensing [3]_ in images and other document, including a specific Creative Commons schema.
One of the challenges of advertising licensing and terms of use in WMS and other web mapping services is that the terms are usually advertised separately from the actual content. So a WMS service might specify terms in the Capabilities document, but the images themselves will be unmarked. Embedding license URLs inside the images themselves using a standard markup allows organizations to be unambiguous about the conditions attached to their content.
The goal of this change is to allow users the option of embedding XMP metadata in their MapServer output using an open source XMP utility library.
2. Proposed Technical Change
2.1. Driver Support
libexempi [4]_ provides a standard C interface for reading and writing XMP content from multiple image formats. One limitation of libexempi (and all other XMP libraries we investigated) is that it only works on existing files. That means that any image that is going to be tagged with metadata must be written to the disk first. Fortunately the GDAL image driver already writes a temporary file to disk for every request, so we propose that XMP support be available only when using the GDAL output format driver.
For example::
OUTPUTFORMAT
NAME png
DRIVER "GDAL/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
The XMP metadata embedding code will be called in msSaveImageGDAL just before the temporary file is streamed back to the client.
2.2. Map File Configuration
Metadata information is written per-image, so will be stored in the METADATA block of the WEB object in the MAP file.
The metadata key for each tag will have the form "xmp_<namespace>_<tag>", so for example: "xmp_dc_Title", for the Dublin Core title.
Three namespaces will be supported by default:
- "meta" which is the standard XMP tag set [5]_
- "cc" which is the Creative Commons tag set [6]_
- "dc" which is the Dublin Core tag set [7]_
- "rights" which is the standard XMP Rights tag set [8]_
- "exif" which is the EXIF tags set [9]_
- "tiff" which is the TIFF tags set [10]_
- "crs" which is the Photoshop Camera Raw Schema [11]_
- "photoshop" which is the Photoshop tag set [12]_
Within those names spaces, users can specify any tag. The MapServer code will not check that the tags are valid for the namespace, that responsibility will fall to the user.
Here are some examples of common tags within the default name spaces:
- xmp_rights_Marked ('true' or 'false') indicates whether the image is copyright (true) or public domain (false)
- xmp_rights_WebStatement (URL) link to a page that explains the terms and conditions under which the image is licensed
- xmp_rights_UsageTerms (text) a description of the terms and conditions under which the image is licensed. To save image space and ensure licensing is kept up to date, the web statement is preferred over the usage terms.
- xmp_cc_License (URL) link to the creative commons license that applies to this image (e.g. http://creativecommons.org/licenses/by-sa/2.0/)
- xmp_cc_MorePermissions (URL) link to a page describing additional terms and conditions beyond the CC terms
- xmp_cc_AttributionURL (URL) link to a page of information about the author or organization that produced the content
- xmp_cc_AttributionName (text) name of the person or organization that produced the content
- xmp_dc_Title (text) title of the image
- xmp_dc_Rights (text) textual description of the license regime of the image
Here is an example of setting tags using the default namespaces::
WEB
METADATA
"xmp_rights_Marked" "true"
"xmp_cc_License" "http://creativecommons.org/licenses/by-sa/2.0/"
"xmp_cc_AttributionURL" "http://www.landgate.wa.gov.au/corporate.nsf/web/About+Us"
"xmp_cc_AttributionName" "Landgate (landgate.wa.gov.au)"
END
END
Users can also set up their own namespace and insert tags into it. The user must include a metadata key of the form "xmp_<name>_namespace" with a namespace URI as the value. Once the namespace is declared, other metadata keys of the usual form can be used to insert tags into the XMP.
Here is an example of setting tags using a custom namespace::
WEB
METADATA
"xmp_lightroom_namespace" "http://ns.adobe.com/lightroom/1.0/"
"xmp_lightroom_PrivateRTKInfo" "My Information Here"
END
END
2.3. Build Configuration
XMP metadata support will require the presence of the libexempi library. The library must be requested or pointed to directly to using the --with-exempi=[yes|no|path] configuration option in the ./configure script. If --with-exempi is not used, XMP metadata support will not be enabled.
3. Implementation Details
3.1. Files Affected
The following files will be modified for this RFC::
Makefile.in
Makefile.vc
mapgdal.c
mapxmp.c
configure.in
configure
3.2. Bug ID
The ticket for RFC 7X (containing proof-of-concept code) can be found here (Bug `3932`_).
3.3. Documentation
Documentation for this feature will be added to the appropriate map file documentation (metadata keywords) and a separate howto document will be created explaining XMP metadata.
4. Enhancements
The proposal suggests a set of licensing keywords dictated by Creative Commons, but XMP supports a huge number of other keywords. Allowing generic access to XMP keywords could make the facility more widely useful.
5. Voting history
None
.. [5] http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/XMP.html#xmp
.. [6] http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/XMP.html#cc
.. [7] http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/XMP.html#dc
.. [8] http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/XMP.html#xmpRights
.. [9] http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/XMP.html#exif
.. [10] http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/XMP.html#tiff
.. [11] http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/XMP.html#crs
.. [12] http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/XMP.html#photoshop
.. _3932: http://trac.osgeo.org/mapserver/ticket/3932
