[mapserver-dev] github migration complete
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 4 00:07:51 EDT 2012
Thomas,
This is great - Thanks!
I can create new tickets for 4270-4273 if you want, no big deal.
You might want to post the git:/... urls to clone for the various
repositories for those of us that need some clue :)
Thanks for all your effort to get this moved.
-Steve W
On 4/3/2012 11:55 PM, thomas bonfort wrote:
> Hi devs,
> As you may have seen or been notified, the transition of the code to
> github is complete, and the tickets have been imported. All code
> committers should normally have been added, I'm still missing jeff's
> userid for the docs.
> - How can we set trac and svn to read-only?
> - I can assign open issues to the person they were assigned in trac,
> but have refrained from doing so until now to avoid notification email
> spamming. I will do this in a couple of days once the dust has
> settled, unless you specifically oppose to this in this thread.
> - There are 5 major repositories: mapserver, docs, msautotest,
> mapcache, and tinyows. The mapcache and tinyows subdirectories in
> mapserver will have to be removed.
> - The tinyows code has been reimported from a dump of the original
> svn, which means it now has history attached.
> - There are a couple of trac issues and svn commits that didn't make
> it into github (i.e. the ones that were created after I got the trac
> dump):
> - from steveW: tickets 4270-4273
> - from steveL: ticket 4269 + commit
> - from paolo: italian doc commit r13314
> - There is a single issue tracker for all repositories
> https://github.com/mapserver/mapserver/issues . The syntx reference is
> here http://github.github.com/github-flavored-markdown/ . You can
> reference commits by their sha1 directly (e.g. "in commit abd234ef ,
> the behavior ...") for commits that belong to the mapserver/mapserver
> repository. For commits in the other repositories, the syntax is
> mapserver/repo at SHA1, you have a nice example in the last comments of
> this ticket https://github.com/mapserver/mapserver/issues/3906 .
> cheers,
> thomas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
