[mapserver-dev] github migration complete
thomas bonfort thomas.bonfort at gmail.com
Fri Apr 6 00:59:31 EDT 2012
I don't have admin/ssh access to our trac instance... having that I
could update it to at least make it clear that it should not be used
anymore.
thomas
On Thu, Apr 5, 2012 at 19:58, Alan Boudreault <aboudreault at mapgears.com> wrote:
> Note sure what's the best way to lock these... perhaps we could first put
> the database read-only.
> On 12-04-05 01:48 PM, Stephen Woodbridge wrote:
>> Steve,
>> I don't know what it takes, but can we lock trac and svn so they are
>> read only?
>> I think an announce is a good idea.
>> -Steve W
>> On 4/5/2012 12:08 PM, Lime, Steve D (DNR) wrote:
>>> I think we need to get some communications out to mapserver-users
>>> letting them know about the change and that they should avoid
>>> creating or updating trac tickets for days. If we're ready to send
>>> them to github then that should be mentioned to. There were several
>>> tickets updated that I saw emails on.
>>> Perhaps we could update the http://trac.osgeo.org/mapserver/ wiki
>>> page to direct users appropriately?
>>> Steve
>>> -----Original Message----- From:
>>> mapserver-dev-bounces at lists.osgeo.org
>>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of thomas
>>> bonfort Sent: Tuesday, April 03, 2012 10:55 PM To: MapServer Dev
>>> Mailing List Subject: [mapserver-dev] github migration complete
>>> Hi devs,
>>> As you may have seen or been notified, the transition of the code to
>>> github is complete, and the tickets have been imported. All code
>>> committers should normally have been added, I'm still missing jeff's
>>> userid for the docs.
>>> - How can we set trac and svn to read-only? - I can assign open
>>> issues to the person they were assigned in trac, but have refrained
>>> from doing so until now to avoid notification email spamming. I will
>>> do this in a couple of days once the dust has settled, unless you
>>> specifically oppose to this in this thread. - There are 5 major
>>> repositories: mapserver, docs, msautotest, mapcache, and tinyows. The
>>> mapcache and tinyows subdirectories in mapserver will have to be
>>> removed. - The tinyows code has been reimported from a dump of the
>>> original svn, which means it now has history attached. - There are a
>>> couple of trac issues and svn commits that didn't make it into github
>>> (i.e. the ones that were created after I got the trac dump): - from
>>> steveW: tickets 4270-4273 - from steveL: ticket 4269 + commit - from
>>> paolo: italian doc commit r13314
>>> - There is a single issue tracker for all repositories
>>> https://github.com/mapserver/mapserver/issues . The syntx reference
>>> is here http://github.github.com/github-flavored-markdown/ . You can
>>> reference commits by their sha1 directly (e.g. "in commit abd234ef ,
>>> the behavior ...") for commits that belong to the mapserver/mapserver
>>> repository. For commits in the other repositories, the syntax is
>>> mapserver/repo at SHA1, you have a nice example in the last comments of
>>> this ticket https://github.com/mapserver/mapserver/issues/3906 .
>>> cheers, thomas _______________________________________________
>>> mapserver-dev mailing list mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>> _______________________________________________ mapserver-dev mailing
> Alan Boudreault
> http://www.mapgears.com/
