[mapserver-dev] MapServer pie chart enhancements
thomas bonfort thomas.bonfort at gmail.com
Thu Apr 12 05:48:30 EDT 2012
I'm fine with the changes, add when you please...
thomas
On Wed, Apr 11, 2012 at 23:30, Lime, Steve D (DNR)
<Steve.Lime at state.mn.us> wrote:
> Seems a relatively straightforward addition to me.  I’d be ok with the
> addition…
> Steve
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Tamas Szekeres
> Sent: Wednesday, April 11, 2012 2:12 PM
> To: thomas bonfort
> Cc: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] MapServer pie chart enhancements
> Hi Thomas,
> I would just use 3 specific functions (linear, sqrt, log) as the possible
> values of   CHART_SIZE_FUNCTION
> Best regards,
> Tamas
> 2012/4/11 thomas bonfort <thomas.bonfort at gmail.com>
> Hi Tamas,
> How would you express this in a pseudo-generic way inside the
> processing keys? Are there any other functions that would make sense
> here?
> thomas
> On Wed, Apr 11, 2012 at 20:14, Tamas Szekeres <szekerest at gmail.com> wrote:
>> Hi Devs,
>> One of our client requires an addition which could provide nonlinear
>> function to visualize the size of the pies depending on the source
>> attribute. Currently we can specify the chart size as follows:
>> PROCESSING "CHART_SIZE_RANGE = itemname minsize maxsize minval maxval"
>> This can provide the size as linear function of the item value. As an
>> enhancement we would like to add further kind of functions (like square
>> root
>> or logarithm) to enhance the visual appearance (see the images attached).
>> This addition could be implemented by introducing a new processing option
>> (like: CHART_SIZE_FUNCTION ) and by adding a switch to the size
>> calculation
>> in mapchart.c.
>> For example with the square root function we could use:
>> diameter=MS_NINT(
>> mindiameter+
>> (sqrt((diameter-minvalue))/sqrt((maxvalue-minvalue)))*
>> (maxdiameter-mindiameter));
>> What do you think about this change?
>> Best regards,
>> Tamas
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
