[mapserver-dev] 6.2 release
thomas bonfort
thomas.bonfort at gmail.com
Thu Apr 12 09:35:19 EDT 2012
The github issues have been updated to reflect these changes,and the
4268 branch has been created with the code. I'm not competent enough
on the this to know if this is the correct way of adressing the
underlying issue so will stop commenting here, but someone
knowledgeable just needs to merge it in master if it seems correct.
regards,
thomas
On Wed, Apr 11, 2012 at 22:11, Martin Kofahl <M.Kofahl at gmx.net> wrote:
> Hi,
> I did add an update for the axis orientation code, see http://trac.osgeo.org/mapserver/attachment/ticket/4273/mapaxisorder.v798.csv.patch. As long MapServer has to use it's own table, this is an quite important patch to stay compatible with OWS clients.
> In case there's someone to review the patch at http://trac.osgeo.org/mapserver/attachment/ticket/4268/axes_orientation.patch, code size an lookup performance for the axis orientation could be enhanced in 6.2, too.
> Kind regards,
> Martin
> -------- Original-Nachricht --------
>> Datum: Wed, 11 Apr 2012 18:26:42 +0200
>> Von: thomas bonfort <thomas.bonfort at gmail.com>
>> An: MapServer Dev Mailing List <mapserver-dev at lists.osgeo.org>
>> Betreff: [mapserver-dev] 6.2 release
>> Hi devs,
>> Are there any outstanding new features or bugs that prevent us from
>> beginning the 6.2 release cycle? If not, I will formalize a release
>> plan in the coming days.
>> Given the transition to git, I propose to take the lead on this
>> release in order to:
>> - update our branching workflow
>> - update our guidelines as to where bugfixes should be committed
>> - update the tarball-making tasks
>> cheers,
>> thomas
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
