[mapserver-dev] RPMs from trunk
Stephan Meißl
stephan at meissl.name
Fri Apr 20 10:34:02 EDT 2012
Hi devs,
not being an expert I've put some effort to generate RPMs for CentOS
from current trunk. I partially succeeded to update the spec file to the
new build procedure (see attached). Note that I did not manage to build
PHP packages and that I had to disable this
check: /usr/lib/rpm/check-buildroot
Anyway, maybe this can be of some help to the MapServer RPM maintainers.
Question to all: What do you think about adding build files (spec file
for RPM) to the repository for reference?
The pull request 4289 [1] includes some changes that where necessary
along the way. Thanks for review and any comments. If there are no
objections I'll merge it next week.
@Thomas: I hope I'm using git and gitgut as intended?
cu
Stephan
[1] https://github.com/mapserver/mapserver/pull/4289
Type: text/x-rpm-spec
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120420/37dfecfe/mapserver-6.1.dev.bin
