[mapserver-dev] OGR-Spatialite don't retrieve attributes with GetFeatureInfo
Andrea Peri aperi2007 at gmail.com
Fri Aug 10 15:05:39 PDT 2012
>Hi,
>I do some tests.
>Using the gdal-1.9.1.
>I can see that MapServer (dev version) cannot retrieve the attributes using
>the GetFeatureInfo request.
>I do this tests:
>With a mapfile like this:
>    TYPE POLYGON
>    CONNECTIONTYPE OGR
>    CONNECTION "/path-to/db.sqlite"
>    DATA 'PARTICELLE'
>I see the GetFeatureInfo will work (apparently) but return always the
>message
>"Search returned no results. No matching record(s) found."
>The log also report this:
>[Fri Aug 10 16:25:52 2012].705407 msQueryByPoint(): Search returned no
>If I try to set a label on a field, I can see it correctly is showed.
>So the labels work, and the getFeatureInfo wrong the result.
I discovered something more.
I notice infact that the MapServer is don't able to retrieve the attributes
from Spatialite only with MultiPolygons.
I see infact with POLYGONS it work correctly.
It seem to be a bug of GDAL.
Regards.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120811/492827df/attachment.html>
