[mapserver-dev] mapserver user can not make the shapefile data correctly show in the browser
李杨 gisyangli at gmail.com
Wed Aug 22 09:50:28 PDT 2012
Hello,
respected everyone,
I have a problem when using Mapserver. I just using Maperver to rend an
shapefile on ubuntu 12.04. but the expect image is not correctly showing, i
think there maybe some problem with my mapfile set, especially with
IMAGEURL define?
 I use a guide in the link :
http://www.gistutor.com/mapserver/3-beginner-mapserver-tutorials/7-how-to-generate-a-simple-map-using-mapserver-and-a-shapefile.html
 I assign the mapfile & template.html&start.html in my www DIR,
which is like this:
mapfiel.map:
MAP
NAME parcels_map
STATUS ON
SIZE 420 300
EXTENT 489885 5450946 490904 5451637
UNITS METERS
SHAPEPATH "shapefiles"
IMAGECOLOR 255 255 255
 WEB
TEMPLATE "template.html"
IMAGEPATH "/var/www/output/"
IMAGEURL "/output/"
END
  LAYER
NAME "parcel_boundaries"
DATA parcels
STATUS DEFAULT
TYPE POLYGON
CLASS
NAME "parcels_color"
COLOR 255 215 0
END
END
 # end of map file
END
 starrtmap.html:
<html>
<head><title>Creating a simple image using Mapserver and a
Shapefile</title></head>
<body bgcolor="#FFFFFF">
<h2>Creating a simple image using Mapserver and a Shapefile</h2>
<p><hr><p>
This page simply contains a link which sends a set of instructions to the
Mapserver application using a mapfile.<br />
The information stored within the mapfile tells the Mapserver application
how to draw the map.<p>
<!-- The following link sends the local file structure path of the mapfile
to the web location of the mapserver executable file -->
<A HREF="http://localhost/cgi-bin/mapserv?map=/var/www/mapfile.map">
Click on this link</A> to view a map generated using a Shapefile.
<p><hr><p>
 </body>
</html>
 template.html:
<!-- MapServer Template -->
<html>
<head><title>Simple Mapserver Template HTML Document</title></head>
<body bgcolor=#AAAAAA>
<h2>The image below was illustrated based on the instructions sent in the
mapfile.</h2>
<!-- When using Mapserver with a template, the Mapserver application looks
for the [img] tag within the template document to place the map -->
<img src="/[img]" border=1>
</body>
</html>
 when I run the “http://localhost/cgi-bin/mapserv?map=/var/www/mapfile.map”
in my address colum.
The expect map is not shown.
 The page is showing content of template.html expectly, but there is only a
image icon , but with no picture. And the status bar in the firefox brower
is showing : conecting to output ..
 I notice that in the var/www/output DIR, there have been some png file
generated. And is the png containing the polygon in the shapefile. Every
time when I click the “
http://localhost/cgi-bin/mapserv?map=/var/www/mapfile.map” link, a new png
file is generated in output DIR.
 I want to know if the IMAGEURL in the mapfile is set wrongly? Why the png
is genrated correctly but not showing in the browser? Any one can help me?
Yang Li
GIS Developer
P.R.China
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120823/a48b6d80/attachment.html>
