[mapserver-dev] RFC 86: Call for vote
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Dec 13 06:29:06 PST 2012
Thomas,
This update helps a lot.
If a user uses a name like %table% and also has a run time parameter
table=blabla is there any interaction or potential issues.
Thank you,
-SteveW
On 12/13/2012 5:13 AM, thomas bonfort wrote:
> Steve, Daniel, Jeff,
> In
> https://github.com/mapserver/docs/commit/db54f7cfa603a545a3a9308ee434527f462d9f0d
> I have tried to address the issues you arose.
> HTH,
> Thomas
> On Wed, Dec 12, 2012 at 5:01 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> +1 SteveW but ...
> I think the RFC needs some updating to address Jeff's issue for the
> doc team. Also re-reading the RFC I noticed that it does not specify
> if the the ranges need to be ordered or not and in the email thread
> you mentioned the there has to be a zero item as you check for that.
> So I think some additional detail, to help the doc team. This could
> be added once the code is checked in based on the final implementation.
> BTW, I think this is an excellent design given all the discussion we
> had earlier on it and it will a very useful feature for users. Thanks!
> On 12/12/2012 6:06 AM, thomas bonfort wrote:
> Hi guys,
> Please vote on RFC 86, scale dependent token replacements (
> http://mapserver.org/__development/rfc/ms-rfc-86.html
> <http://mapserver.org/development/rfc/ms-rfc-86.html> )
> I'll start with my +1.
> thanks,
> thomas
> _________________________________________________
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/mapserver-dev
> <http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
