[mapserver-dev] [mapscript][python] does outputformatObj has missing method?
Umberto Nicoletti
umberto.nicoletti at gmail.com
Wed Dec 19 00:26:37 PST 2012
On Mon, Dec 17, 2012 at 10:08 PM, Yves Jacolin
<yves.jacolin at camptocamp.com>wrote:
> Hello,
> Currently working with python mapscript on outputformat object, I have
> some difficulties to get the correct information.
> First, I can't get outputformat list from map obj. The documentation says:
> outputformatlist : outputFormatObj[]
> Array of the available output formats.
> Note
> Currently only available for C#. A proper typemaps should be implemented
> for the other languages.
> And indeed, even if the method appears, this is not working.
I have done a quick test in python and java and it seems to return just one
(selected?) outputformatObj.
Please open an issue.
> Second, I can't get config option list without knowing the options. I can
> use getOption( name, value ) method but it suppose to know the config name.
> Am I wrong somewhere? Do you know a method to get this information or do I
> need to fill a ticket?
Assuming you're referring to MS_IMAGEMODE_* the option name and values are
present in the mapscript module. I am not sure there is a way to enumerate
them.
Open an issue for that too and I'll make sure to have a look at them.
Cheers,
Umberto
Thanks,
> Y.
> Responsable Formation et Support
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel (France) : +33 4 79 26 57 98
> Tel (Suisse) : 02 16 190 10 43 (new)
> Mob. : +33 6 18 75 42 21
> Fax : 04 79 70 15 81
> Mail : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20121219/f2a61b14/attachment.html>
