[mapserver-dev] [mapscript][python] does outputformatObj has missing method?
Yves Jacolin
yves.jacolin at camptocamp.com
Mon Dec 17 13:08:57 PST 2012
Hello,
Currently working with python mapscript on outputformat object, I have some
difficulties to get the correct information.
First, I can't get outputformat list from map obj. The documentation says:
outputformatlist : outputFormatObj[]
Array of the available output formats.
Note
Currently only available for C#. A proper typemaps should be implemented
for the other languages.
And indeed, even if the method appears, this is not working.
Second, I can't get config option list without knowing the options. I can
use getOption( name, value ) method but it suppose to know the config name.
Am I wrong somewhere? Do you know a method to get this information or do I
need to fill a ticket?
Thanks,
Y.
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 79 26 57 98
Tel (Suisse) : 02 16 190 10 43 (new)
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
<yves.jacolin at camptocamp.com>
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20121217/e25ae543/attachment.html>
