[mapserver-dev] Docs externals checkout
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Fri Feb 3 13:41:58 EST 2012
I thought this was fixed if you used a newish version of SVN.
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Howard Butler
Sent: Friday, February 03, 2012 9:06 AM
To: mapserver-dev List
Subject: [mapserver-dev] Docs externals checkout
Jeff,
Every time I check out the docs tree, including a clean checkout, I get a complaint:
> svn: URL 'https://svn.osgeo.org/mapserver/trunk/mapserver/MIGRATION_GUIDE.txt' refers to a file, not a directory
Is this the intended behavior? I haven't followed in a while, but I remember some discussion about keeping the migration guide up higher in the tree instead of down in the docs. svn:external cannot refer to a single file as far as I know, and must instead refer to a directory. To make the migration guide in the top of the tree work, would we need an external in the docs tree back to trunk? We probably don't want that either...
Any ideas?
Howard_______________________________________________
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
