[mapserver-dev] Release of MapServer 6.0.2 and 5.6.8
Daniel Morissette
dmorissette at mapgears.com
Wed Feb 8 16:12:02 EST 2012
The MapServer team announces the release of MapServer versions 6.0.2 and
5.6.8.
No new functionality has been added. 6.0.2 is a maintenance release that
fixes a few issues found in since 6.0.1 including a recently discovered
security vulnerability in the handling of WFS filters inside a SLD. The
list of fixes since 6.0.1 is included at the end of this message.
Versions 5.6.8 includes fixes for the same WFS Filter security
vulnerability plus a few bug fixes that were backported since the last
official release. See the 5.6.8 HISTORY.TXT file for additional information.
Source and binary downloads:
The source code is available at:
http://mapserver.org/download.html
The binary distributions listed in the download page should be updated
shortly with binaries for the new 6.0.2 release (and in some cases 5.6.8).
The MapServer Team
Version 6.0.2 (2012-02-08):
- Fix security issue with quote escape in WFS GetFeature Filter (#4087)
- Fixed lexer buffer size issue with single quotes in a string (#4175)
- Raster layer fails to be drawn if the window is less than half a pixel
(#4172)
- Fixed SLD with FILTER doesn't apply properly to database layers (#4112)
- Fixed a problem with calls to labelInImage() (maplabel.c) when label
gutter
and label buffers are both used (#3303). Also changed the usage
around that
function to make it easier to understand. At a result the
"labelcache_map_edge_buffer" processing option (i.e. gutter) can be
provided
as a positive or negative value. (closes #1355 too)
- Added label->style markers to collision detection (#4133)
- Fixed single pixel coverages in WCS 2.0 (#4110)
- Fixed subsetting in WCS 2.0 (#4099)
- Fixed segfault when calling classObj::updateFromString() with SYMBOL
(#4062)
- fix rendering offset on thick GD lines (#3962)
- fix segfault on join with postgresql tables (#4074)
- Fixed Python Mapscript does not write COLOR to reference map (#4042)
- Fixed cannot add a style to a label in PHP/SWIG Mapscript (#4038)
- Add missing outputFormat support in WFS GetFeature POST XML requests
(#4052)
- Fixed schema validity issue for WCS 1.1 GetCoverage responses (#4047)
- fix centroid geomtransform parser (#4029)
- PHP MapScript is missing many styleObj properties (#3901)
- Added GEOMTRANSFORM in writeStyle function
- WCS 1.0: Fix crash with some _rangeset_axes values (#4020)
- Changed msDrawVectorLayer() not to cache shapes if attribute binding is
present after the first style (#3976)
- Fix mapscript to build when TRUE macro is not defined (#3926)
- Fix mapscript php build issues with MSVC (#4004)
- PHP/Mapscript: Segmentation fault when getting complex object using
PHP 5.2 (#3930)
- Fixed contains operator in logical expresions (#3974)
- Fix incorrect rendering of GD lines between 1 and 2 pixels wide (#3962)
