[mapserver-dev] Found a strange performance issue
Stephen Woodbridge woodbri at swoodbridge.com
Mon Feb 20 19:11:58 EST 2012
I am developing a new mapfile file and have run into a very strange
performance issue.
I have created a skeleton mapfile with all/most the layers like:
     LAYER
         NAME "linear_water"
         METADATA
             "ows_title"     "Streams and Rivers"
             "ows_srs"       "EPSG:4269 EPSG:4326"
             "ows_abstract"  "Streams and Rivers from the U.S. Census
LINEARWATER data layer."
         END
         TYPE LINE
         TILEINDEX "tidx-LINEARWATER"
         PROJECTION
             "+proj=longlat +ellps=GRS80 +datum=NAD83" #EPSG: 4269
         END
         INCLUDE "map-LINEARWATER.inc"
     END
Where the INCLUDE is just an empty file. So in effect, a layer with data
source and projection defined and no CLASS definitions. My plan is to
populate these one at a time as I develop the mapfile.
So, if I run shp2img -m mymap.map -o junk it runs quickly and returns
the expected image. In OL, I make a WMS request in spherical mercator
projection. And the request times out.
Running from the command line with the same WMS request is below. I
think the code is reading all the data and re-projecting it only to do
nothing with it because there are no CLASS or STYLE definitions.
OK, I realize this is a corner case, but it seems that we should be
smart enough to realize that there is not styling so it should skip over
it. I can probably mitigate this by adding a huge MINSCALEDENOM until
I'm ready to play with it.
My concern is that this seems like a hidden gotcha from a performance
point of view.
Thoughts?
-Steve W
MapServer version 5.6.8 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
woodbri at mappy:/u/data/tgr2011-maps$ /u/www/cgi-bin/mapserv
QUERY_STRING="MAP=%2Fu%2Fdata%2Ftgr2011-maps%2Ftiger2011-tmp.map&FORMAT=image%2Fpng&MAP_IMAGETYPE=agg_qn&LAYERS=Tiger_2011&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-17444764.183944,-498980.7376244,-3747249.058944,10263352.574876&WIDTH=700&HEIGHT=550"
[Mon Feb 20 18:52:09 2012].983341 msDrawMap(): WMS/WFS set-up and query,
0.000s
[Mon Feb 20 18:52:10 2012].25715 msDrawMap(): Layer 1 (World Z1), 0.042s
[Mon Feb 20 18:52:10 2012].30751 msDrawMap(): Layer 3 (World Boundaries
Z1), 0.005s
[Mon Feb 20 18:52:10 2012].36963 msDrawMap(): Layer 6 (World Names Z0),
0.006s
[Mon Feb 20 18:52:10 2012].37661 msDrawMap(): Layer 9 (Equator), 0.001s
[Mon Feb 20 18:52:10 2012].56812 msDrawMap(): Layer 10 (state), 0.019s
[Mon Feb 20 18:52:10 2012].198219 msDrawMap(): Layer 11 (county), 0.141s
[Mon Feb 20 18:52:10 2012].848536 msDrawMap(): Layer 12 (cousub), 0.650s
[Mon Feb 20 18:52:11 2012].180890 msDrawMap(): Layer 13 (place), 0.332s
[Mon Feb 20 18:52:11 2012].963980 msDrawMap(): Layer 14
(area_landmarks), 0.783s
[Mon Feb 20 18:52:11 2012].972431 msDrawMap(): Layer 15 (military), 0.008s
[Mon Feb 20 18:52:46 2012].969970 msDrawMap(): Layer 16 (area_water),
34.997s
[Mon Feb 20 18:55:28 2012].560355 msDrawMap(): Layer 17 (linear_water),
161.590s
[Mon Feb 20 18:55:29 2012].742523 msDrawMap(): Layer 18 (primary_roads),
1.182s
[Mon Feb 20 18:55:44 2012].193565 msDrawMap(): Layer 19 (pri_sec_roads),
14.451s
[Mon Feb 20 18:55:45 2012].820018 msDrawMap(): Layer 20 (rails), 1.626s
[Mon Feb 20 18:59:17 2012].81059 msDrawMap(): Layer 21 (roads), 211.261s
[Mon Feb 20 18:59:30 2012].812374 msDrawMap(): Layer 22
(point_landmarks), 13.731s
[Mon Feb 20 18:59:30 2012].812444 msDrawLabelCache():
labelcache_map_edge_buffer = -10
[Mon Feb 20 18:59:30 2012].821460 msDrawMap(): Drawing Label Cache, 0.009s
[Mon Feb 20 18:59:30 2012].821492 msDrawMap() total time: 440.840s
[Mon Feb 20 18:59:30 2012].921310 msSaveImage() total time: 0.100s
[Mon Feb 20 18:59:30 2012].921672 mapserv request processing time
(msLoadMap not incl.): 440.962s
[Mon Feb 20 18:59:30 2012].921698 msFreeMap(): freeing map at 0x1a8ba60.
