[mapserver-dev] Building Java-Mapscript with Java >1.5?
Stephan Holl
stephan.holl at intevation.de
Wed Feb 22 05:28:54 EST 2012
Hello devs,
using OpenSuse-Buildservice for building MapServer 6.0.1 on
SLES_11-SP1, the build process outputs the following:
ERROR: the files below contain java bytecode for something later than
java 1.5,
ERROR: please set the javac target to 1.5 or lower.
Does that mean, that java 1.5 or lower is required for java mapscript?
TIA
Stephan
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120222/a9dac62f/signature-0001.bin
