[mapserver-dev] Building Java-Mapscript with Java >1.5?
Umberto Nicoletti umberto.nicoletti at gmail.com
Wed Feb 22 06:17:05 EST 2012
On Wednesday, February 22, 2012, Stephan Holl wrote:
> Hello devs,
> using OpenSuse-Buildservice for building MapServer 6.0.1 on
> SLES_11-SP1, the build process outputs the following:
>  ERROR: the files below contain java bytecode for something later than
>  java 1.5,
>  ERROR: please set the javac target to 1.5 or lower.
> Does that mean, that java 1.5 or lower is required for java mapscript?
> Not that I know. I will try to build svn trunk with 1.6 today and let you
know.
Umberto
> TIA
>        Stephan
> Stephan Holl <stephan.holl at intevation.de <javascript:;>> | Tel.: +49
> (0)541-33 508 3663
> Intevation GmbH, Neuer Graben 17, 49074 OS  |  AG Osnabrück - HR B 18998
> Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120222/b35b74a6/attachment.html
