[mapserver-dev] Building Java-Mapscript with Java >1.5?
Umberto Nicoletti umberto.nicoletti at gmail.com
Thu Feb 23 15:24:46 EST 2012
Did check and I was able to successfully build svn trunk with jdk 1.6.29.
Can you give more details or logs?
On Wednesday, February 22, 2012, Umberto Nicoletti wrote:
> On Wednesday, February 22, 2012, Stephan Holl wrote:
>> Hello devs,
>> using OpenSuse-Buildservice for building MapServer 6.0.1 on
>> SLES_11-SP1, the build process outputs the following:
>>  ERROR: the files below contain java bytecode for something later than
>>  java 1.5,
>>  ERROR: please set the javac target to 1.5 or lower.
>> Does that mean, that java 1.5 or lower is required for java mapscript?
>> Not that I know. I will try to build svn trunk with 1.6 today and let you
> know.
> Umberto
>> TIA
>>        Stephan
>> Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
>> Intevation GmbH, Neuer Graben 17, 49074 OS  |  AG Osnabrück - HR B 18998
>> Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120223/eb4f3244/attachment.html
