[mapserver-dev] Building Java-Mapscript with Java >1.5?
Stephan Holl
stephan.holl at intevation.de
Fri Feb 24 02:46:34 EST 2012
Hello Umberto,
Umberto Nicoletti <umberto.nicoletti at gmail.com>, [20120223 - 21:24:46]
> Did check and I was able to successfully build svn trunk with jdk
> 1.6.29. Can you give more details or logs?
Good to know.
I placed the logs here:
ftp://ftp.intevation.de/users/stephan/mapserver/javac-1.6-errors.txt
It uses openjdk 1.6.x for building. The build-process seems fine, what
I am unsure about is the error-message. Is this a mapserver-specific
error-message or a packaging-problem.
Best regards
Stephan
> >> Hello devs,
> >> using OpenSuse-Buildservice for building MapServer 6.0.1 on
> >> SLES_11-SP1, the build process outputs the following:
> >> ERROR: the files below contain java bytecode for something later
> >> than java 1.5,
> >> ERROR: please set the javac target to 1.5 or lower.
> >> Does that mean, that java 1.5 or lower is required for java
> >> mapscript?
> >> Not that I know. I will try to build svn trunk with 1.6 today and
> >> let you
> > know.
> > Umberto
> >> TIA
> >> Stephan
> >> Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33
> >> 508 3663 Intevation GmbH, Neuer Graben 17, 49074 OS | AG
> >> Osnabrück - HR B 18998 Geschäftsführer: Frank Koormann, Bernhard
> >> Reiter, Dr. Jan-Oliver Wagner
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120224/b53195ed/signature.bin
