[mapserver-dev] Building Java-Mapscript with Java >1.5?
Umberto Nicoletti
umberto.nicoletti at gmail.com
Fri Feb 24 04:23:20 EST 2012
Ok, I understand, but the error it spits out is deceiving.
It's in fact complaining the complied classes are for java >= 1.6 and this
goes against the spec file which only requires 1.5 or later.
Work around it by:
1. using 1.5 to compile mapscript
2. or add the '--target 1.5' option to javac and continue compiling with 1.6
3. change the spec file to require java >= 1.6
Cheers,
Umberto
On Fri, Feb 24, 2012 at 10:10 AM, Stephan Holl
<stephan.holl at intevation.de>wrote:
> Hello Umberto,
> Umberto Nicoletti <umberto.nicoletti at gmail.com>, [20120224 - 09:25:29]
> > I think it's a package problem and specifically it's
> > /usr/lib/rpm/brp-check-bytecode-version
> > which is triggering the fail. Is there a java-specific param in the
> > spec file?
> Not that I know of.
> > I can take a look at the spec file if you want.
> You can find it here:
> https://build.opensuse.org/package/view_file?file=mapserver.spec&package=mapserver&project=Application%3AGeo&rev=a6a132713f06dd4c534c92cacefbd59a
> Thanks for looking into this.
> Best regards
> Stephan
> > On Fri, Feb 24, 2012 at 8:46 AM, Stephan Holl
> > > Hello Umberto,
> > > Umberto Nicoletti <umberto.nicoletti at gmail.com>, [20120223 -
> > > 21:24:46]
> > > > Did check and I was able to successfully build svn trunk with jdk
> > > > 1.6.29. Can you give more details or logs?
> > > Good to know.
> > > I placed the logs here:
> > > ftp://ftp.intevation.de/users/stephan/mapserver/javac-1.6-errors.txt
> > > It uses openjdk 1.6.x for building. The build-process seems fine,
> > > what I am unsure about is the error-message. Is this a
> > > mapserver-specific error-message or a packaging-problem.
> > > Best regards
> > > Stephan
> > > > >> Hello devs,
> > > > >> using OpenSuse-Buildservice for building MapServer 6.0.1 on
> > > > >> SLES_11-SP1, the build process outputs the following:
> > > > >> ERROR: the files below contain java bytecode for something
> > > > >> later than java 1.5,
> > > > >> ERROR: please set the javac target to 1.5 or lower.
> > > > >> Does that mean, that java 1.5 or lower is required for java
> > > > >> mapscript?
> > > > >> Not that I know. I will try to build svn trunk with 1.6 today
> > > > >> and let you
> > > > > know.
> > > > > Umberto
> > > > >> TIA
> > > > >> Stephan
> > > > >> Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33
> > > > >> 508 3663 Intevation GmbH, Neuer Graben 17, 49074 OS | AG
> > > > >> Osnabrück - HR B 18998 Geschäftsführer: Frank Koormann,
> > > > >> Bernhard Reiter, Dr. Jan-Oliver Wagner
> > > Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508
> > > 3663 Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück -
> > > HR B 18998 Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr.
> > > Jan-Oliver Wagner
> Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
> Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
> Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120224/3fe60aed/attachment-0001.html
