[mapserver-dev] wish list item for Mapserver - reduce font size to
make labels fit in a polygon
Mark Volz
MarkVolz at co.lyon.mn.us
Wed Feb 22 14:45:55 EST 2012
Hello,
Currently when labeling polygons, using MINFEATURESIZE AUTO will create a label only if the label will fit in the polygon. I was looking to see if Mapserver had a way to reduce the font size if a label doesn't fit. This would be similar to "Reduce font size" when using ArcGIS Maplex. Where you can start to label using one size, and if the label doesn't fit the label engine will keep trying with smaller font sizes until it reaches a user defined minimum label size.
I don't know if this can be done, would be difficult to program, or if it would impact performance. But I think it would be useful.
P.S. Let me know if I should be sending ideas elsewhere.
Thank You
Mark Volz
GIS Specialist
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120222/dd2b2f35/attachment.html
