[mapserver-dev] libtool build: call for vote
Umberto Nicoletti umberto.nicoletti at gmail.com
Thu Feb 23 08:49:03 EST 2012
Thomas,
Just want to let you know I have just commited some changes to fix an error
that prevented Java mapscript from working.
While I was at it I've also tackled
http://trac.osgeo.org/mapserver/ticket/2595#comment:5 (blushing, mutters an
apology) so now the shared library is called libjavamapscript and is fully
numbered like its mapserver counterpart.
cheers,
Umberto
On Thu, Dec 22, 2011 at 7:36 PM, thomas bonfort <thomas.bonfort at gmail.com>wrote:
> I have committed the changes in r12907, along with changes to the
> builds of python and php mapscript.
> building steps:
> ./configure [previous opts] --prefix=/usr/local
> make
> sudo make install
> cp /usr/local/bin/mapserv [cgi-bin-directory] #do *not* directly copy
> the mapserv binary from our top-level source directory, as it is a
> wrapper script and not compiled machine code.
> python and php mapscript are both built with make && make install. The
> other mapscript flavors will probably not compile, I will get back to
> them in a second step if no one wants to volunteer on the task.
> please report back any issues in this thread or with a trac ticket.
> regards,
> thomas
> On Wed, Dec 21, 2011 at 05:04, Perry Nacionales <pnaciona at gmail.com>
> wrote:
> > +1
> > -Perry
> > On Tue, Dec 20, 2011 at 8:37 AM, thomas bonfort <
> > wrote:
> >> I would like to call for a vote on the recent discussion regarding the
> >> switch to libtool.
> >> Given the reticences regarding the blackbox behavior libtool, I will
> >> commit to implementing a --with(out)-libtool switch to our configure
> >> script should issues arise with the libtool builds. Note that in that
> >> case I will *not* be supporting building a dso module.
> >> +1
> >> thomas
> >> _______________________________________________
> >> mapserver-dev mailing list
> >> mapserver-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120223/334f6ac9/attachment.html
