[mapserver-dev] libtool build: call for vote
    thomas bonfort
    thomas.bonfort at gmail.com
    Thu Feb 23 08:54:15 EST 2012
Hi Umberto,
Thanks for dealing with this. Just one remark: I don't think it's a
good idea to put in the readme that you can copy .libs/libxxx.so to
the destination folder: that file is private to libtool, and should
only be manipulated through libtool itself.
cheers,
thomas
On Thu, Feb 23, 2012 at 14:49, Umberto Nicoletti
<umberto.nicoletti at gmail.com> wrote:
> Thomas,
> Just want to let you know I have just commited some changes to fix an error
> that prevented Java mapscript from working.
> While I was at it I've also
> tackled http://trac.osgeo.org/mapserver/ticket/2595#comment:5 (blushing,
> mutters an apology) so now the shared library is called libjavamapscript and
> is fully numbered like its mapserver counterpart.
> cheers,
> Umberto
> On Thu, Dec 22, 2011 at 7:36 PM, thomas bonfort <thomas.bonfort at gmail.com>
> wrote:
>> I have committed the changes in r12907, along with changes to the
>> builds of python and php mapscript.
>> building steps:
>> ./configure [previous opts] --prefix=/usr/local
>> make
>> sudo make install
>> cp /usr/local/bin/mapserv [cgi-bin-directory] #do *not* directly copy
>> the mapserv binary from our top-level source directory, as it is a
>> wrapper script and not compiled machine code.
>> python and php mapscript are both built with make && make install. The
>> other mapscript flavors will probably not compile, I will get back to
>> them in a second step if no one wants to volunteer on the task.
>> please report back any issues in this thread or with a trac ticket.
>> regards,
>> thomas
>> On Wed, Dec 21, 2011 at 05:04, Perry Nacionales <pnaciona at gmail.com>
>> wrote:
>> > +1
>> > -Perry
>> > On Tue, Dec 20, 2011 at 8:37 AM, thomas bonfort
>> > wrote:
>> >> I would like to call for a vote on the recent discussion regarding the
>> >> switch to libtool.
>> >> Given the reticences regarding the blackbox behavior libtool, I will
>> >> commit to implementing a --with(out)-libtool switch to our configure
>> >> script should issues arise with the libtool builds. Note that in that
>> >> case I will *not* be supporting building a dso module.
>> >> +1
>> >> thomas
>> >> _______________________________________________
>> >> mapserver-dev mailing list
>> >> mapserver-dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
