[mapserver-dev] - How to compile 6.2
Fabian Schindler fabian.schindler at eox.at
Sun Jan 15 07:37:25 EST 2012
You probably have to refresh your Makefile. Try it with:
make clean
make distclean
Now you have to rerun ./configure using the '--with...' switches you require.
Now you should be able to run 'make' again.
HTH
scott159 at free.fr schrieb:
I try to compile mapserver 6.2 but it's seems that only "make" doesn't enought. I compile library GD, GDAL ... but I have errors when I launch "make" from mapserver 6.2. May be errors come from libtool ? I don't know ...
What's command lines are necessary to try mapserver 6.2 dev ?
Thanks
scott
_____________________________________________
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120115/45921c31/attachment.html
