[mapserver-dev] - How to compile 6.2
Stephan Meißl
stephan at meissl.name
Sun Jan 15 12:31:30 EST 2012
Don't forget to run make install which is mandatory now.
Citing Thomas:
building steps:
./configure [previous opts] --prefix=/usr/local
make
sudo make install
cp /usr/local/bin/mapserv [cgi-bin-directory] #do *not* directly copy
the mapserv binary from our top-level source directory, as it is a
wrapper script and not compiled machine code.
There are switches to compile Python and PHP MapScript in the steps
above if needed.
cu
Stephan
On Sun, 2012-01-15 at 13:37 +0100, Fabian Schindler wrote:
> You probably have to refresh your Makefile. Try it with:
> make clean
> make distclean
> Now you have to rerun ./configure using the '--with...' switches you
> require.
> Now you should be able to run 'make' again.
> HTH
> scott159 at free.fr schrieb:
> Hi,
> I try to compile mapserver 6.2 but it's seems that only "make" doesn't enought. I compile library GD, GDAL ... but I have errors when I launch "make" from mapserver 6.2. May be errors come from libtool ? I don't know ...
> What's command lines are necessary to try mapserver 6.2 dev ?
> Thanks
> scott
> ______________________________________________________________
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
