[mapserver-dev] Trunk problems - Apache2 crashing creating
	cgi-bin/.libs
    Havard Tveite
    havard.tveite at umb.no
    Wed Jan 18 08:21:03 EST 2012
Thanks.
The problem was that I had copied the wrapper script
to the cgi-bin.  It worked when I changed to the
correct mapserv file.
Provided that we settle for the new build system, we
should make sure that it is reflected in the documentation.
If someone would file some documentation tickets (with the
necessary information), I can try to help.
The README.CONFIGURE file needs an overhaul (or should be
removed).
Håvard
On 1/18/2012 1:10 PM, thomas bonfort wrote:
> ---------- Message transféré ----------
> De : "thomas bonfort" <thomas.bonfort at gmail.com <mailto:thomas.bonfort at gmail.com>>
> Date : 18 janv. 2012 19:09
> Objet : Re: [mapserver-dev] Trunk problems - Apache2 crashing creating cgi-bin/.libs
> À : "Smith, Michael ERDC-CRREL-NH" <Michael.Smith at usace.army.mil <mailto:Michael.Smith at usace.army.mil>>
> To clarify Mike 's advice:
> - you configure with --prefix=/usr/local (or another location)
> - you run make install
> - you copy/symlink $prefix/bin/mapserv to your cgi-bin directory
> - the $prefix/bin/mapserv is not a wrapper script, the one in the source directory is (and therefore cannot be used by copying it directly to the cgi-bin dir)
> Le 18 janv. 2012 18:45, "Smith, Michael ERDC-CRREL-NH" <Michael.Smith at usace.army.mil <mailto:Michael.Smith at usace.army.mil>> a écrit :
>     Havard,
>     This is due to the new build configuration that uses libtool. Now, you
>     need to do a make install which will copy the binaries to you $PREFIX/bin
>     directory and then you copy the mapserv file (which is now a wrapper) to
>     your cgi-bin dir.
>     Mike
>     Michael Smith
>     US Army Corps
>     Remote Sensing GIS/Center
>     On 1/18/12 4:34 AM, "Havard Tveite" <havard.tveite at umb.no <mailto:havard.tveite at umb.no>> wrote:
>      >I recently updated to the latest version of trunk.
>      >configure and make went fine, and the binary seemed to
>      >work (mapserv -v).
>      >shp2img seems to be OK.
>      >However, when I tried to run it through Apache I get
>      >an internal server error with the following in the
>      >Apache error log:
>      >mkdir: cannot create directory `/usr/lib/cgi-bin/.libs': Permission denied
>      >/usr/bin/ld: cannot open output file
>      >/usr/lib/cgi-bin/.libs/2915-lt-mapserv: No such file or directory
>      >collect2: ld returned 1 exit statusn
>      >Premature end of script headers: mapserver-trunk
>      >I have tested with a few map files.
>      >I am using Apache2 on Debian Lenny, and everything was
>      >OK with my build from the end of November.
>      >I have noticed that the --with-httpd is gone from configure.
>      >I have not included --with-apache-module in configure.
>      >I am hesitant to file a bug, as I guess I have missed
>      >something.  Does anyone have an idea about what it can be?
>      >I have looked in the migration guide, but could not find
>      >anything there.
>      >mapserv -v
>      >MapServer version 6.1-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>      >  SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE
>      >  SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>      >  SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>      >  SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS
>      >  INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>      >I have built using:
>      >make clean
>      >./configure --prefix=/usr/local --enable-debug --with-freetype=/usr
>      >--with-zlib=/usr --with-png=/usr --with-libiconv=/usr/local
>      >--with-gd=/usr/local --with-proj=/usr/local
>      >--with-ogr=/usr/local/bin/gdal-config
>      >--with-gdal=/usr/local/bin/gdal-config
>      >--with-postgis=/usr/local/pgsql/835/bin/pg_config --with-wfs --with-wcs
>      >--with-wmsclient --with-wfsclient --with-php=/usr/bin/php-config
>      >--with-geos --with-fastcgi --with-threads --with-jpeg --with-cairo
>      >--with-apxs=/usr/bin/apxs2 --with-apr-config=/usr/bin/apr-config
>      >make
>      >Håvard
>      >Håvard Tveite
>      >Department of Mathematical Sciences and Technology, UMB
>      >Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
>      >Phone: +47 64965483 <tel:%2B47%2064965483> Fax: +47 64965401 <tel:%2B47%2064965401> http://www.umb.no/imt/
>      >_______________________________________________
>      >mapserver-dev mailing list
>      >mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>      >http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Håvard Tveite
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
