Fwd: Re: [mapserver-dev] Trunk problems - Apache2 crashing creating
cgi-bin/.libs
thomas bonfort
thomas.bonfort at gmail.com
Wed Jan 18 07:10:08 EST 2012
---------- Message transféré ----------
De : "thomas bonfort" <thomas.bonfort at gmail.com>
Date : 18 janv. 2012 19:09
Objet : Re: [mapserver-dev] Trunk problems - Apache2 crashing creating
cgi-bin/.libs
À : "Smith, Michael ERDC-CRREL-NH" <Michael.Smith at usace.army.mil>
To clarify Mike 's advice:
- you configure with --prefix=/usr/local (or another location)
- you run make install
- you copy/symlink $prefix/bin/mapserv to your cgi-bin directory
- the $prefix/bin/mapserv is not a wrapper script, the one in the source
directory is (and therefore cannot be used by copying it directly to the
cgi-bin dir)
Le 18 janv. 2012 18:45, "Smith, Michael ERDC-CRREL-NH" <
Michael.Smith at usace.army.mil> a écrit :
Havard,
> This is due to the new build configuration that uses libtool. Now, you
> need to do a make install which will copy the binaries to you $PREFIX/bin
> directory and then you copy the mapserv file (which is now a wrapper) to
> your cgi-bin dir.
> Mike
> Michael Smith
> US Army Corps
> Remote Sensing GIS/Center
> On 1/18/12 4:34 AM, "Havard Tveite" <havard.tveite at umb.no> wrote:
> >I recently updated to the latest version of trunk.
> >configure and make went fine, and the binary seemed to
> >work (mapserv -v).
> >shp2img seems to be OK.
> >However, when I tried to run it through Apache I get
> >an internal server error with the following in the
> >Apache error log:
> >mkdir: cannot create directory `/usr/lib/cgi-bin/.libs': Permission denied
> >/usr/bin/ld: cannot open output file
> >/usr/lib/cgi-bin/.libs/2915-lt-mapserv: No such file or directory
> >collect2: ld returned 1 exit statusn
> >Premature end of script headers: mapserver-trunk
> >I have tested with a few map files.
> >I am using Apache2 on Debian Lenny, and everything was
> >OK with my build from the end of November.
> >I have noticed that the --with-httpd is gone from configure.
> >I have not included --with-apache-module in configure.
> >I am hesitant to file a bug, as I guess I have missed
> >something. Does anyone have an idea about what it can be?
> >I have looked in the migration guide, but could not find
> >anything there.
> >mapserv -v
> >MapServer version 6.1-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> > SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE
> > SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> > SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> > SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS
> > INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> >I have built using:
> >make clean
> >./configure --prefix=/usr/local --enable-debug --with-freetype=/usr
> >--with-zlib=/usr --with-png=/usr --with-libiconv=/usr/local
> >--with-gd=/usr/local --with-proj=/usr/local
> >--with-ogr=/usr/local/bin/gdal-config
> >--with-gdal=/usr/local/bin/gdal-config
> >--with-postgis=/usr/local/pgsql/835/bin/pg_config --with-wfs --with-wcs
> >--with-wmsclient --with-wfsclient --with-php=/usr/bin/php-config
> >--with-geos --with-fastcgi --with-threads --with-jpeg --with-cairo
> >--with-apxs=/usr/bin/apxs2 --with-apr-config=/usr/bin/apr-config
> >make
> >Håvard
> >Håvard Tveite
> >Department of Mathematical Sciences and Technology, UMB
> >Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
> >Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
> >_______________________________________________
> >mapserver-dev mailing list
> >mapserver-dev at lists.osgeo.org
> >http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120118/1c4e5cfc/attachment-0001.html
