[mapserver-dev] WMS GetCapabilities response truncated to 4096 bytes on windows 2008 Server
Tamas Szekeres szekerest at gmail.com
Fri Jan 20 14:36:55 EST 2012
The client reported this problem for mapserver 5.4 actually. I've just
tested with mapserver 5.6 and it doesn't indeed produce the problem, though
it is not clear to me how it was getting fixed. I'll require to track down
the changes between 5.4 and 5.6 to see which changeset affects this
behaviour.
Best regards,
Tamas
2012/1/20 Jeff McKenna <jmckenna at gatewaygeomatics.com>
> On 12-01-19 6:18 PM, Tamas Szekeres wrote:
>> I have also found this thread which describes exactly the same issue:
>> http://osgeo-org.1803224.n2.**nabble.com/GetCapabilities-**
>> response-being-truncated-**td3234081.html<http://osgeo-org.1803224.n2.nabble.com/GetCapabilities-response-being-truncated-td3234081.html>
> Yeah it's been around a while, but since I can't reproduce it
> often/regularly it is very hard to file a ticket and verify.
> -jeff
> ______________________________**_________________
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/mapserver-dev<http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120120/253bf304/attachment.html
