[mapserver-dev] - configure
Alan Boudreault aboudreault at mapgears.com
Mon Jan 30 07:59:07 EST 2012
IIRC, I don't think mapserver apache module is ready to be used. It is
really experimental. Using MapServer as FCGI is probably better for now.
For mapcache, you should compile/install it manually in the mapcache
subdirectory: http://mapserver.org/trunk/mapcache/install.html . The
loading instruction are there as well. For PHP support, you should add
the --with-php=/path/to/php-config . Mine is located at /usr/bin/php-config.
Thanks,
Alan
On 12-01-28 07:52 AM, scott159 at free.fr wrote:
> Hi,
> I would like to compile mapserver-6.2-dev but I have some questions to succeed :
> - With "--with-apache-module", I don't know where I can find mod_mapserver and mod_mapcache after compilation. Where are necessary files to activate in httpd.conf ?
> - To configure mapserver and mapcache with cgi mode, I think add these lines in httpd.conf, is it ok ?
> <IfModule mod_mapcache>
>     <Directory /path/to/directory>
>        Order Allow,Deny
>        Allow from all
>     </Directory>
>     MapCacheAlias /mapcache "/path/to/directory/mapcache.xml"
> </IfModule>
> <IfModule mod_mapserver>
>        Order Allow,Deny
>        Allow from all
>     </Directory>
>     ScriptAlias /mapserv "/path/to/directory/mapserv"
> </IfModule>
> -->  http://localhost/mapserv
> -->  http://localhost/mapcache
> - For fcgi mode :
> <IfModule mod_fcgid.c>
>     IPCCommTimeout 120
>     MaxProcessCount 10
>     FcgidInitialEnv "MAPCACHE_CONFIG_FILE" "/path/to/directory/mapcache.xml"
>     ScriptAlias /map.fcgi "/path/to/directory/mapcache"
>     <Location /map.fcgi>
>        Order Allow,Deny
>        Allow from all
>        SetHandler fcgid-script
>     </Location>
>     ScriptAlias /mapserv.fcgi "/path/to/directory/mapserv"
>     <Location /mapserv.fcgi>
>        Order Allow,Deny
>        Allow from all
>     </Location>
> </IfModule>
> -->  http://localhost/mapserv.fcgi
> -->  http://localhost/map.fcgi
> - "--with-php=yes" is it right flag to activate PHP MapScript Extension or can I specify path ?
> Thanks a lot
> scott
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Alan Boudreault
http://www.mapgears.com/
