[mapserver-dev] Installing multiple versions of MapServer
thomas bonfort
thomas.bonfort at gmail.com
Mon Jul 2 08:09:39 PDT 2012
--prefix should be sufficient. You might need to also use different
LD_LIBRARY_PATH settings alongside different prefixes if that is not
enough (that might be the case on older systems).
thomas
On Mon, Jul 2, 2012 at 5:07 PM, Lime, Steve D (DNR)
<Steve.Lime at state.mn.us> wrote:
> With the new libtool build process it’s unclear to me how to install
> multiple version of MapServer on the same box. In general I can’t upgrade
> everything in one fell swoop. Perhaps I’m missing something obvious. Is
> there a recommended approach (perhaps just using PREFIX at configure time)?
> Steve
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
