[mapserver-dev] Installing multiple versions of MapServer
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Mon Jul 2 08:12:52 PDT 2012
How would you do "different LD_LIBRARY_PATH settings alongside different prefixes" in the case where you're running multiple CGI or fast CGI installs?
-----Original Message-----
From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Sent: Monday, July 02, 2012 10:10 AM
To: Lime, Steve D (DNR)
Cc: MapServer Dev Mailing List
Subject: Re: [mapserver-dev] Installing multiple versions of MapServer
--prefix should be sufficient. You might need to also use different LD_LIBRARY_PATH settings alongside different prefixes if that is not enough (that might be the case on older systems).
thomas
On Mon, Jul 2, 2012 at 5:07 PM, Lime, Steve D (DNR) <Steve.Lime at state.mn.us> wrote:
> With the new libtool build process it’s unclear to me how to install
> multiple version of MapServer on the same box. In general I can’t
> upgrade everything in one fell swoop. Perhaps I’m missing something
> obvious. Is there a recommended approach (perhaps just using PREFIX at configure time)?
> Steve
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
