[mapserver-dev] Build issues with current git master
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Jun 27 09:49:28 PDT 2012
Hi Alan,
Ok thanks.  I've created a ticket so we can make changes/test through
that: https://github.com/mapserver/mapserver/issues/4362
-jeff
On 12-06-26 9:24 PM, Alan Boudreault wrote:
> Things build on Linux. This seems to be related to my last php upgrade.
> Will try to take a look at this soon.
> Alan
> On 12-06-26 06:59 PM, Jeff McKenna wrote:
>> Hi Angelos,
>> You mentioned that you have no troubles building PHP mapscript with
>> git-master, can you confirm this for me again?  I seem to get the
>> following
>> errors today on Windows:
>>     Creating library php_mapscript.lib and object php_mapscript.exp
>> php_mapscript_util.obj : error LNK2019: unresolved external symbol
>> _mapscript_create_label
>> leader referenced in function _mapscript_fetch_object
>> php_mapscript_util.obj : error LNK2001: unresolved external symbol
>> _mapscript_ce_labellead
>> er
>> label.obj : error LNK2001: unresolved external symbol
>> _mapscript_ce_labelleader
>> class.obj : error LNK2001: unresolved external symbol
>> php_mapscript.obj : error LNK2019: unresolved external symbol
>> _zm_startup_labelleader refe
>> renced in function _zm_startup_mapscript
>> mapscript_i.obj : error LNK2019: unresolved external symbol _msCopyLine
>> referenced in func
>> tion _lineObj_clone
>> _msCopyProjection referenced i
>> n function _projectionObj_clone
>> php_mapscript.dll : fatal error LNK1120: 5 unresolved externals
>> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
>> 9.0\VC\BIN\link.EXE"
>> ' : return code '0x460'
>> Stop.
>> 9.0\VC\BIN\nmake.EXE
>> "' : return code '0x2'
>> Stop.
>> -jeff
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/Build-issues-with-current-git-master-tp4983668p4984085.html
>> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
