[mapserver-dev] Mapserver trunk & postgis 2.0
Salvatore Larosa
S_Larosa at libero.it
Thu Mar 8 06:00:28 EST 2012
Sorry, I was convinced that Andrea had the problem of a raster display!
However, taking advantage of the availability of Stephen!
My map file is:
MAP
IMAGETYPE png
EXTENT -100.0146627565979998 9.9853372434017587 -69.9853372434015597
40.0146627565981987
SIZE 600 600
#SHAPEPATH "../data"
CONFIG MS_ERRORFILE "stderr"
DEBUG 10
LAYER
NAME katrina
TYPE raster
STATUS ON
DATA "PG:host=localhost port=5432 dbname='workshop' user='postgres'
password='*********' schema='public' table='katrina' mode='2'"
PROCESSING "NODATA=-32768"
PROCESSING "SCALE=-100.5,100.5"
PROCESSING "SCALE_BUCKETS=201"
END
END
and then:
sam at debian~$ shp2img -m /home/sam/www/katrina.map -o /home/sam/www/katrina.png
-l katrina
[Thu Mar 8 11:50:33 2012].404176 msDrawMap(): rendering using outputformat
named png (AGG/PNG).
[Thu Mar 8 11:50:33 2012].404298 msDrawMap(): WMS/WFS set-up and query, 0.000
s
[Thu Mar 8 11:50:33 2012].406252 msDrawRasterLayerLow(katrina): entering.
[Thu Mar 8 11:50:33 2012].690629 LoadGDALImage(katrina): NODATA value -32768
in GDAL
file or PROCESSING directive largely ignored. Not yet fully supported for
unclassified scaled data. The NODATA value is excluded from auto-scaling
min/max computation, but will not be transparent.
[Thu Mar 8 11:50:33 2012].693783 LoadGDALImage(katrina): NODATA value -32768
in GDAL
[Thu Mar 8 11:50:33 2012].696929 LoadGDALImage(katrina): NODATA value -32768
in GDAL
[Thu Mar 8 11:50:33 2012].700532 msDrawMap(): Layer 0 (katrina), 0.296s
[Thu Mar 8 11:50:33 2012].700575 msDrawMap(): Drawing Label Cache, 0.000s
[Thu Mar 8 11:50:33 2012].700609 msDrawMap() total time: 0.298s
[Thu Mar 8 11:50:33 2012].725200 msSaveImage(/home/sam/www/katrina.png) total
time: 0.025s
[Thu Mar 8 11:50:33 2012].725349 msFreeMap(): freeing map at 0x269ed40.
i get an image totally gray!
I need to check if the problem is in the GDAL libraries (r24093)!
Thanks
>----Messaggio originale----
>Da: woodbri at swoodbridge.com
>Data: 07/03/2012 18.25
>A: <mapserver-dev at lists.osgeo.org>
>Ogg: Re: [mapserver-dev] Mapserver trunk & postgis 2.0
>First it would help if you post your LAYER block or DATA statement.
>In the MAP section put something like:
> DEBUG 10
>And you might also try adding the DEBUG to the actual LAYER block. Under
>apache, the error messages will go into the apache error.log
>-Steve W
>On 3/7/2012 11:35 AM, Salvatore Larosa wrote:
>> I am having the same problem, but I fear that the
>> command raster2pgsql did not work properly,
>> at least in my case!
>> Can you see your raster display somewhere?
>> How did your map file?
>> Here [1] it seems to work!
>> Regards!
>> [1] - http://trac.osgeo.org/postgis/ticket/497
>> Da: aperi2007 at gmail.com
>> Data: 05/03/2012 15.06
>> Ogg: [mapserver-dev] Mapserver trunk & postgis 2.0
>> Hi,
>> Is supported postgis 2.0 on Mapserver trunk ?
>> I'm testing that version of mapserver and will use postgis 2.0 beta2.
>> I'm having some trouble, mapserver give no errors, but the map is
>> fully white.
>> I see also the bounding-box is forgotten.
>> How is possible to growth the log level to have more information
>> from mapserver ?
>> thx,
>> Andrea Peri
>> qwerty àèìòù
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
