[mapserver-dev] Mapserver trunk & postgis 2.0
Andrea Peri
aperi2007 at gmail.com
Wed Mar 7 15:07:04 EST 2012
Thx,
for response.
Meanwhile I guess to found the real problem.
It was a path forward a wrong TrueType font file.
When correct the path forward a good truetype font, it the mapserver begin
to give correct maps.
This is the layer I'm using:
LAYER
NAME "idcomuni"
STATUS ON
TYPE POLYGON
#DUMP true
EXTENT 1487422.221679 4672163.860500 1839051.274580 4930953.559500
CONNECTIONTYPE postgis
CONNECTION "user=postgres password=controllo dbname=test host=localhost
port=5432"
DATA "geometry from test.am_com_region_am_com using unique gid using
srid=3003"
PROJECTION
"+init=epsg:3003"
END
METADATA
"wms_title" "Confini Comunali"
"wms_srs" "EPSG:3003 EPSG:4326"
"wms_extent" "1487422.221679 4672163.860500 1839051.274580
4930953.559500"
"wms_bbox_extended" "true"
END
OPACITY 100
PROCESSING "APPROXIMATION_SCALE=FULL"
LABELITEM "nome"
CLASS
NAME 'am_com_region_am_com'
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 103 132 169
ANTIALIAS true
END
LABEL
POSITION auto
SIZE 8
COLOR 0 0 0
TYPE truetype
FONT LiberationMono-Regular
END
END
END
Regards,
Andrea.
My
2012/3/7 Stephen Woodbridge <woodbri at swoodbridge.com>
> First it would help if you post your LAYER block or DATA statement.
> In the MAP section put something like:
> CONFIG MS_ERRORFILE "stderr"
> DEBUG 10
> And you might also try adding the DEBUG to the actual LAYER block. Under
> apache, the error messages will go into the apache error.log
> -Steve W
> On 3/7/2012 11:35 AM, Salvatore Larosa wrote:
>> I am having the same problem, but I fear that the
>> command raster2pgsql did not work properly,
>> at least in my case!
>> Can you see your raster display somewhere?
>> How did your map file?
>> Here [1] it seems to work!
>> Regards!
>> [1] - http://trac.osgeo.org/postgis/**ticket/497<http://trac.osgeo.org/postgis/ticket/497>
>> ----Messaggio originale----
>> Da: aperi2007 at gmail.com
>> Data: 05/03/2012 15.06
>> A: <mapserver-dev at lists.osgeo.org**>
>> Ogg: [mapserver-dev] Mapserver trunk & postgis 2.0
>> Hi,
>> Is supported postgis 2.0 on Mapserver trunk ?
>> I'm testing that version of mapserver and will use postgis 2.0 beta2.
>> I'm having some trouble, mapserver give no errors, but the map is
>> fully white.
>> I see also the bounding-box is forgotten.
>> How is possible to growth the log level to have more information
>> from mapserver ?
>> thx,
>> Andrea Peri
>> qwerty אטלעש
>> ______________________________**_________________
>> mapserver-dev mailing list
>> http://lists.osgeo.org/**mailman/listinfo/mapserver-dev<http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
Andrea Peri
qwerty àèìòù
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120307/bcb84628/attachment.html
