[mapserver-dev] Mapserver trunk & postgis 2.0
Stephen Woodbridge woodbri at swoodbridge.com
Wed Mar 7 12:25:10 EST 2012
First it would help if you post your LAYER block or DATA statement.
In the MAP section put something like:
     CONFIG MS_ERRORFILE "stderr"
     DEBUG 10
And you might also try adding the DEBUG to the actual LAYER block. Under
apache, the error messages will go into the apache error.log
-Steve W
On 3/7/2012 11:35 AM, Salvatore Larosa wrote:
> I am having the same problem, but I fear that the
> command raster2pgsql did not work properly,
> at least in my case!
> Can you see your raster display somewhere?
> How did your map file?
> Here [1] it seems to work!
> Regards!
> [1] - http://trac.osgeo.org/postgis/ticket/497
>     ----Messaggio originale----
>     Da: aperi2007 at gmail.com
>     Data: 05/03/2012 15.06
>     A: <mapserver-dev at lists.osgeo.org>
>     Ogg: [mapserver-dev] Mapserver trunk & postgis 2.0
>     Hi,
>     Is supported postgis 2.0 on Mapserver trunk ?
>     I'm testing that version of mapserver and will use postgis 2.0 beta2.
>     I'm having some trouble, mapserver give no errors, but the map is
>     fully white.
>     I see also the bounding-box is forgotten.
>     How is possible to growth the log level to have more information
>     from mapserver ?
>     thx,
>     Andrea Peri
>     qwerty àèìòù
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
