[mapserver-dev] Mapserver trunk & postgis 2.0
Salvatore Larosa
S_Larosa at libero.it
Wed Mar 7 11:35:14 EST 2012
I am having the same problem, but I fear that the command raster2pgsql did not work properly, at least in my case!
Can you see your raster display somewhere?
How did your map file? Here [1] it seems to work!
Regards!
[1] - http://trac.osgeo.org/postgis/ticket/497
----Messaggio originale----
Da: aperi2007 at gmail.com
Data: 05/03/2012 15.06
A: <mapserver-dev at lists.osgeo.org>
Ogg: [mapserver-dev] Mapserver trunk & postgis 2.0
Is supported postgis 2.0 on Mapserver trunk ?
I'm testing that version of mapserver and will use postgis 2.0 beta2.
I'm having some trouble, mapserver give no errors, but the map is fully white.
I see also the bounding-box is forgotten.
How is possible to growth the log level to have more information from mapserver ?
thx,
Andrea Peri
qwerty àèìòù
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120307/48f19a2b/attachment.html
