[mapserver-dev] 6.2 release notes/announcement
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue Nov 13 08:49:41 PST 2012
At least for the few things I had a hand the doc look fine. There really is some great new stuff. Couple of comments:
- Maybe we should have an TOC at the top?
- I’m not positive ANNOTATION layers can be removed yet without creating a list of specific use/test cases. I could create a before -> after syntax page.
- Unix build/install procedure (IMHO) is a major (or at least minor) new feature that will impact how folks will install multiple versions on the same box. Should we provide guidance?
Steve
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of thomas bonfort
Sent: Tuesday, November 13, 2012 7:14 AM
To: MapServer Dev Mailing List
Subject: Re: [mapserver-dev] 6.2 release notes/announcement
feeling somewhat alone here... :)
Here's an updated release doc: http://ci.mapserver.org/job/docsmaster/lastSuccessfulBuild/artifact/build/html/en/development/announce/6-2.html . If you believe your new feature is insufficiently/incorrectly documented or promoted, please be my guest and amend.
cheers,
thomas
On Fri, Nov 9, 2012 at 4:11 PM, thomas bonfort <thomas.bonfort at gmail.com<mailto:thomas.bonfort at gmail.com>> wrote:
Devs,
I have started a release document [1] for our planned wednesday release. This is still a work in progress, and I will be working on the areas marked "TODO thomas" in the coming days. There are however a number of points that I would need help with, so please have a go at filling in your respective parts.
The ordering of the new features and the major/minor classifications are a first stab, and are open for discussion/modification.
regards,
thomas
[1] http://ci.mapserver.org/job/docsmaster/21/artifact/build/html/en/development/announce/6-2.html
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20121113/326a5a75/attachment-0001.html>
