[mapserver-dev] 6.2 release notes/announcement
Worth Lutz wal3 at mindspring.com
Tue Nov 13 08:54:28 PST 2012
I have seen something about ANNOTATION layers going away. Info relating to
this would be helpful as I am not sure what the effect will be on me.
Worth Lutz
  _____
[mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Lime, Steve D
(DNR)
Sent: Tuesday, November 13, 2012 11:50 AM
To: MapServer Dev Mailing List
Subject: Re: [mapserver-dev] 6.2 release notes/announcement
At least for the few things I had a hand the doc look fine. There really is
some great new stuff. Couple of comments:
-          Maybe we should have an TOC at the top?
-          I'm not positive ANNOTATION layers can be removed yet without
creating a list of specific use/test cases. I could create a before -> after
syntax page.
-          Unix build/install procedure (IMHO) is a major (or at least
minor) new feature that will impact how folks will install multiple versions
on the same box. Should we provide guidance?
Steve
[mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of thomas bonfort
Sent: Tuesday, November 13, 2012 7:14 AM
feeling somewhat alone here... :)
Here's an updated release doc:
http://ci.mapserver.org/job/docsmaster/lastSuccessfulBuild/artifact/build/ht
ml/en/development/announce/6-2.html . If you believe your new feature is
insufficiently/incorrectly documented or promoted, please be my guest and
amend.
cheers,
thomas
On Fri, Nov 9, 2012 at 4:11 PM, thomas bonfort <thomas.bonfort at gmail.com>
wrote:
Devs,
I have started a release document [1] for our planned wednesday release.
This is still a work in progress, and I will be working on the areas marked
"TODO thomas" in the coming days. There are however a number of points that
I would need help with, so please have a go at filling in your respective
parts.
The ordering of the new features and the major/minor classifications are a
first stab, and are open for discussion/modification.
regards,
thomas
[1]
http://ci.mapserver.org/job/docsmaster/21/artifact/build/html/en/development
/announce/6-2.html
  _____
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2013.0.2793 / Virus Database: 2629/5890 - Release Date: 11/12/12
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20121113/4fa26a54/attachment.html>
