[mapserver-dev] Packaging MapCache issue
Angelos Tzotsos gcpp.kalxas at gmail.com
Sun Nov 25 11:13:16 PST 2012
Hi Thomas,
Thank you for the patch. I also used 2 patches from UbuntuGIS.
I have applied the patches and I now get an error about libmapserver.la
not found (in my dev environment it is under /usr/lib64 and not /usr/lib):
http://pastebin.com/pvFCGrYF
Also, if I disable mapserver build support I get an error about httpd.h
not found:
http://pastebin.com/H8FjSTM0
I guess I should patch the same way as for
/usr/include/mapserver/mapserver.h?
Any other ideas?
Thanks,
Angelos
On 11/15/2012 11:24 AM, thomas bonfort wrote:
> On Thu, Nov 15, 2012 at 1:01 AM, Angelos Tzotsos <gcpp.kalxas at gmail.com>wrote:
>> Thanks Thomas,
>> I am thinking that Cmake would be excellent choice to unify building of
>> the whole MapServer Suite at some point.
> there's a lot of black magic happening in our configure script, porting to
> cmake will likely not be a trivial task
> I've created a patch for DESTDIR support, can you have a try at it ?
> https://github.com/tbonfort/mapcache/compare/mapserver:branch-1-0...tbonfort:destdir.diff
> cheers,
> thomas
>> Cheers,
>> Angelos
>> On 11/15/2012 01:32 AM, thomas bonfort wrote:
>>> Angelos,
>>> there's no support for DESTDIR in the mapcache makefiles, and I suppose
>>> that might be the issue. I'll have a look and try to provide you with a
>>> patch.
>>> cheers,
>>> thomas
>>> On Thu, Nov 15, 2012 at 12:04 AM, Angelos Tzotsos <gcpp.kalxas at gmail.com
>>>> wrote:
>>>   Hi all,
>>>> I am trying to create a MapCache rpm for openSUSE and I am getting
>>>> strange
>>>> build behavior:
>>>> http://pastebin.com/8bQ6hZ5E
>>>> make install seems to block my chroot build...
>>>> Any ideas? Am I missing something?
>>>> Best,
>>>> Angelos
>>>> PS. Build source is here:
>>>> https://build.opensuse.org/****package/show?package=mapcache&****<https://build.opensuse.org/**package/show?package=mapcache&**>
>>>> project=home%3Atzotsos%****3AApplication%3AGeo<https://**
>>>> build.opensuse.org/package/**show?package=mapcache&project=**
>>>> home%3Atzotsos%3AApplication%**3AGeo<https://build.opensuse.org/package/show?package=mapcache&project=home%3Atzotsos%3AApplication%3AGeo>
>>>> Angelos Tzotsos
>>>> Remote Sensing Laboratory
>>>> National Technical University of Athens
>>>> http://users.ntua.gr/tzotsos
>>>> ______________________________****_________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/****mailman/listinfo/mapserver-dev<http://lists.osgeo.org/**mailman/listinfo/mapserver-dev>
>>>> **<http://lists.osgeo.org/**mailman/listinfo/mapserver-dev<http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
>> Angelos Tzotsos
Angelos Tzotsos
