[mapserver-dev] Packaging MapCache issue
Angelos Tzotsos
gcpp.kalxas at gmail.com
Sun Nov 25 11:50:41 PST 2012
After patching for apache include folders path I get the following error:
http://pastebin.com/GjEnU7cv
On 11/25/2012 09:13 PM, Angelos Tzotsos wrote:
> Hi Thomas,
> Thank you for the patch. I also used 2 patches from UbuntuGIS.
> I have applied the patches and I now get an error about
> libmapserver.la not found (in my dev environment it is under
> /usr/lib64 and not /usr/lib):
> http://pastebin.com/pvFCGrYF
> Also, if I disable mapserver build support I get an error about
> httpd.h not found:
> http://pastebin.com/H8FjSTM0
> I guess I should patch the same way as for
> /usr/include/mapserver/mapserver.h?
> Any other ideas?
> Thanks,
> Angelos
> On 11/15/2012 11:24 AM, thomas bonfort wrote:
>> On Thu, Nov 15, 2012 at 1:01 AM, Angelos Tzotsos
>> <gcpp.kalxas at gmail.com>wrote:
>>> Thanks Thomas,
>>> I am thinking that Cmake would be excellent choice to unify building of
>>> the whole MapServer Suite at some point.
>> there's a lot of black magic happening in our configure script,
>> porting to
>> cmake will likely not be a trivial task
>> I've created a patch for DESTDIR support, can you have a try at it ?
>> https://github.com/tbonfort/mapcache/compare/mapserver:branch-1-0...tbonfort:destdir.diff
>> cheers,
>> thomas
>>> Cheers,
>>> Angelos
>>> On 11/15/2012 01:32 AM, thomas bonfort wrote:
>>>> Angelos,
>>>> there's no support for DESTDIR in the mapcache makefiles, and I
>>>> suppose
>>>> that might be the issue. I'll have a look and try to provide you
>>>> with a
>>>> patch.
>>>> cheers,
>>>> thomas
>>>> On Thu, Nov 15, 2012 at 12:04 AM, Angelos Tzotsos
>>>>> wrote:
>>>> Hi all,
>>>>> I am trying to create a MapCache rpm for openSUSE and I am getting
>>>>> strange
>>>>> build behavior:
>>>>> http://pastebin.com/8bQ6hZ5E
>>>>> make install seems to block my chroot build...
>>>>> Any ideas? Am I missing something?
>>>>> Best,
>>>>> Angelos
>>>>> PS. Build source is here:
>>>>> https://build.opensuse.org/****package/show?package=mapcache&****<https://build.opensuse.org/**package/show?package=mapcache&**>
>>>>> project=home%3Atzotsos%****3AApplication%3AGeo<https://**
>>>>> build.opensuse.org/package/**show?package=mapcache&project=**
>>>>> home%3Atzotsos%3AApplication%**3AGeo<https://build.opensuse.org/package/show?package=mapcache&project=home%3Atzotsos%3AApplication%3AGeo>
>>>>> Angelos Tzotsos
>>>>> Remote Sensing Laboratory
>>>>> National Technical University of Athens
>>>>> http://users.ntua.gr/tzotsos
>>>>> ______________________________****_________________
>>>>> mapserver-dev mailing list
>>>>> mapserver-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/****mailman/listinfo/mapserver-dev<http://lists.osgeo.org/**mailman/listinfo/mapserver-dev>
>>>>> **<http://lists.osgeo.org/**mailman/listinfo/mapserver-dev<http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
>>> Angelos Tzotsos
Angelos Tzotsos
