[mapserver-dev] Packaging MapCache issue
Eichner, Andreas - SID-NLKM Andreas.Eichner at sid.sachsen.de
Sun Nov 25 23:25:59 PST 2012
[   16s] /bin/sh: apxs: command not found
This tool is missing. At least under Debian it's called apxs2. Explicitly
specifying it via --with-apxs= might help.
> -----Ursprüngliche Nachricht-----
> Von: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] Im Auftrag von
> Angelos Tzotsos
> Gesendet: Sonntag, 25. November 2012 20:51
> An: thomas bonfort
> Cc: mapserver-dev at lists.osgeo.org
> Betreff: Re: [mapserver-dev] Packaging MapCache issue
> After patching for apache include folders path I get the
> following error:
> http://pastebin.com/GjEnU7cv
> On 11/25/2012 09:13 PM, Angelos Tzotsos wrote:
> > Hi Thomas,
> > Thank you for the patch. I also used 2 patches from UbuntuGIS.
> > I have applied the patches and I now get an error about
> > libmapserver.la not found (in my dev environment it is under
> > /usr/lib64 and not /usr/lib):
> > http://pastebin.com/pvFCGrYF
> > Also, if I disable mapserver build support I get an error about
> > httpd.h not found:
> > http://pastebin.com/H8FjSTM0
> > I guess I should patch the same way as for
> > /usr/include/mapserver/mapserver.h?
> > Any other ideas?
> > Thanks,
> > Angelos
> > On 11/15/2012 11:24 AM, thomas bonfort wrote:
> >> On Thu, Nov 15, 2012 at 1:01 AM, Angelos Tzotsos
> >> <gcpp.kalxas at gmail.com>wrote:
> >>> Thanks Thomas,
> >>> I am thinking that Cmake would be excellent choice to
> unify building of
> >>> the whole MapServer Suite at some point.
> >> there's a lot of black magic happening in our configure script,
> >> porting to
> >> cmake will likely not be a trivial task
> >> I've created a patch for DESTDIR support, can you have a
> try at it ?
> https://github.com/tbonfort/mapcache/compare/mapserver:branch-
> 1-0...tbonfort:destdir.diff
> >> cheers,
> >> thomas
> >>> Cheers,
> >>> Angelos
> >>> On 11/15/2012 01:32 AM, thomas bonfort wrote:
> >>>> Angelos,
> >>>> there's no support for DESTDIR in the mapcache makefiles, and I
> >>>> suppose
> >>>> that might be the issue. I'll have a look and try to provide you
> >>>> with a
> >>>> patch.
> >>>> cheers,
> >>>> thomas
> >>>> On Thu, Nov 15, 2012 at 12:04 AM, Angelos Tzotsos
> >>>>> wrote:
> >>>>   Hi all,
> >>>>> I am trying to create a MapCache rpm for openSUSE and I
> am getting
> >>>>> strange
> >>>>> build behavior:
> >>>>> http://pastebin.com/8bQ6hZ5E
> >>>>> make install seems to block my chroot build...
> >>>>> Any ideas? Am I missing something?
> >>>>> Best,
> >>>>> Angelos
> >>>>> PS. Build source is here:
> https://build.opensuse.org/****package/show?package=mapcache&*
***<https://build.opensuse.org/**package/show?> package=mapcache&**>
> >>>>> project=home%3Atzotsos%****3AApplication%3AGeo<https://**
> >>>>> build.opensuse.org/package/**show?package=mapcache&project=**
> home%3Atzotsos%3AApplication%**3AGeo<https://build.opensuse.or
g/package/show?package=mapcache&project=home%3Atzotsos%> 3AApplication%3AGeo>
> >>>>> Angelos Tzotsos
> >>>>> Remote Sensing Laboratory
> >>>>> National Technical University of Athens
> >>>>> http://users.ntua.gr/tzotsos
> >>>>> ______________________________****_________________
> >>>>> mapserver-dev mailing list
> http://lists.osgeo.org/****mailman/listinfo/mapserver-dev<http
://lists.osgeo.org/**mailman/listinfo/mapserver-dev>
> **<http://lists.osgeo.org/**mailman/listinfo/mapserver-dev<htt
p://lists.osgeo.org/mailman/listinfo/mapserver-dev>
> >>> Angelos Tzotsos
> Angelos Tzotsos
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
