[mapserver-dev] Packaging MapCache issue
Angelos Tzotsos
gcpp.kalxas at gmail.com
Mon Nov 26 01:48:26 PST 2012
Hi Eichner,
Thanks for your reply.
apxs is installed through the apache2-devel package and specified in my
spec file:
https://build.opensuse.org/package/view_file?expand=1&file=mapcache.spec&package=mapcache&project=home%3Atzotsos%3AApplication%3AGeo&rev=8484fa6a86b663b8d13ca92492b0e4c1
so I am wondering why this error message exists...
On 11/26/2012 09:25 AM, Eichner, Andreas - SID-NLKM wrote:
> [ 16s] /bin/sh: apxs: command not found
> This tool is missing. At least under Debian it's called apxs2. Explicitly
> specifying it via --with-apxs= might help.
>> -----Ursprüngliche Nachricht-----
>> Von: mapserver-dev-bounces at lists.osgeo.org
>> [mailto:mapserver-dev-bounces at lists.osgeo.org] Im Auftrag von
>> Angelos Tzotsos
>> Gesendet: Sonntag, 25. November 2012 20:51
>> An: thomas bonfort
>> Cc: mapserver-dev at lists.osgeo.org
>> Betreff: Re: [mapserver-dev] Packaging MapCache issue
>> After patching for apache include folders path I get the
>> following error:
>> http://pastebin.com/GjEnU7cv
>> On 11/25/2012 09:13 PM, Angelos Tzotsos wrote:
>>> Hi Thomas,
>>> Thank you for the patch. I also used 2 patches from UbuntuGIS.
>>> I have applied the patches and I now get an error about
>>> libmapserver.la not found (in my dev environment it is under
>>> /usr/lib64 and not /usr/lib):
>>> http://pastebin.com/pvFCGrYF
>>> Also, if I disable mapserver build support I get an error about
>>> httpd.h not found:
>>> http://pastebin.com/H8FjSTM0
>>> I guess I should patch the same way as for
>>> /usr/include/mapserver/mapserver.h?
>>> Any other ideas?
>>> Thanks,
>>> Angelos
>>> On 11/15/2012 11:24 AM, thomas bonfort wrote:
>>>> On Thu, Nov 15, 2012 at 1:01 AM, Angelos Tzotsos
>>>> <gcpp.kalxas at gmail.com>wrote:
>>>>> Thanks Thomas,
>>>>> I am thinking that Cmake would be excellent choice to
>> unify building of
>>>>> the whole MapServer Suite at some point.
>>>> there's a lot of black magic happening in our configure script,
>>>> porting to
>>>> cmake will likely not be a trivial task
>>>> I've created a patch for DESTDIR support, can you have a
>> try at it ?
>> https://github.com/tbonfort/mapcache/compare/mapserver:branch-
>> 1-0...tbonfort:destdir.diff
>>>> cheers,
>>>> thomas
>>>>> Cheers,
>>>>> Angelos
>>>>> On 11/15/2012 01:32 AM, thomas bonfort wrote:
>>>>>> Angelos,
>>>>>> there's no support for DESTDIR in the mapcache makefiles, and I
>>>>>> suppose
>>>>>> that might be the issue. I'll have a look and try to provide you
>>>>>> with a
>>>>>> patch.
>>>>>> cheers,
>>>>>> thomas
>>>>>> On Thu, Nov 15, 2012 at 12:04 AM, Angelos Tzotsos
>>>>>>> wrote:
>>>>>> Hi all,
>>>>>>> I am trying to create a MapCache rpm for openSUSE and I
>> am getting
>>>>>>> strange
>>>>>>> build behavior:
>>>>>>> http://pastebin.com/8bQ6hZ5E
>>>>>>> make install seems to block my chroot build...
>>>>>>> Any ideas? Am I missing something?
>>>>>>> Best,
>>>>>>> Angelos
>>>>>>> PS. Build source is here:
>> https://build.opensuse.org/****package/show?package=mapcache&*
> ***<https://build.opensuse.org/**package/show?> package=mapcache&**>
>>>>>>> project=home%3Atzotsos%****3AApplication%3AGeo<https://**
>>>>>>> build.opensuse.org/package/**show?package=mapcache&project=**
>> home%3Atzotsos%3AApplication%**3AGeo<https://build.opensuse.or
> g/package/show?package=mapcache&project=home%3Atzotsos%> 3AApplication%3AGeo>
>>>>>>> Angelos Tzotsos
>>>>>>> Remote Sensing Laboratory
>>>>>>> National Technical University of Athens
>>>>>>> http://users.ntua.gr/tzotsos
>>>>>>> ______________________________****_________________
>>>>>>> mapserver-dev mailing list
>> http://lists.osgeo.org/****mailman/listinfo/mapserver-dev<http
> ://lists.osgeo.org/**mailman/listinfo/mapserver-dev>
>> **<http://lists.osgeo.org/**mailman/listinfo/mapserver-dev<htt
> p://lists.osgeo.org/mailman/listinfo/mapserver-dev>
>>>>> Angelos Tzotsos
>> Angelos Tzotsos
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Angelos Tzotsos
